20 Most Recent Western Digital (WDXB1200BBRNN) 120 GB Hard Drive Questions & Answers
0answers
Power Cord
Be the first to answer 1/30/2012 4:07:33 AM • Western Digital... • Posted on Jan 30, 2012Be the first to answer
I was moving a zip
Give Recuva a try its good at recovering lost files http://www.piriform.com/recuva
But I'm sensing you may have a damaged drive. If so and you need data recovery help this guy does it remotely and works for donations. http://FreeDataRecovery.us
7/20/2011 4:04:02 AM • Western Digital... • Answered on Jul 20, 2011
When I try to remove the external hard drive
if virus in ur external hard drive and ur divice if no any virus in ur both divice then ur ext.hard drive safely unplug...
2/26/2011 9:19:19 PM • Western Digital... • Answered on Feb 26, 2011
Wrote zeros to hard drive
If you wrote zeros to the drive then there is no way of recovering the data. All you can do is format it and start over.
2/19/2011 3:14:39 AM • Western Digital... • Answered on Feb 19, 2011
I wanted to back up
Hi, Thanks for using fixya.
If you have the fake security center go into the path:
C:\Users\(user name)\AppData\Roaming\Microsoft
Look for a folder with 8-10 letter of jibberish and delete it. If windows won't let you do it go into safe mode and do it.
Terry
2/12/2011 8:42:07 AM • Western Digital... • Answered on Feb 12, 2011
How to disable Autorun function
Have you tried renaming autorun.inf or the autorun folder to something else? This file or folder would be in the root directory of the drive.
That would be my guess.
Please be kind when you rate -- I admit this is a guess.
Thanks for using FixYa and Happy New Year
1/2/2011 11:27:19 PM • Western Digital... • Answered on Jan 02, 2011
When I plug the wd
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
12/16/2010 3:29:00 PM • Western Digital... • Answered on Dec 16, 2010
0answers
Just a single question, I
The autoplay function sets a default action everytime you wish to do something with a media file.
So if you put a blank cd in then you can set your cd burning software to launch, or if you plug a memory card or portable hard drive you can set the pc to open the drive,or open your image viewer to view pictures.
If you have not set your autoplay functions, a box will usually just pop up asking what would you like to do
8/14/2010 8:53:36 PM • Western Digital... • Answered on Aug 14, 2010
USB port broke and went inside the hard drive????
Don 't fret too bad just take the cover off and retrieve it and next time don't be so rough your hard drive is a delicate instument not a hockey puck
1/18/2010 7:43:29 AM • Western Digital... • Answered on Jan 18, 2010
It was missed and dropped down..
If it shows in Taskbar that it found new hardware then it does detect the PC board of the hard drive but the drive's head mechanics or the actual disk inside have been damaged by the fall and therefore it cannot read off the drive which means your drive has now permanent damage.
Therefore it cannot be detected at bootup...
You may try a DATA RETRIEVAL company to see if they can get your information off the fallen drive.
7/3/2009 8:42:10 AM • Western Digital... • Answered on Jul 03, 2009
Western Digital 120 GB Model WD1200U017.002 SN WXE0o6620867
1.I will suggest you please partitioned it properly.
2. Check your Registry. Some times people use to FIX Registry for Reading multiple Partitioned External Drive.
3. You must require partition.
4. Have you check the cable which was supplied with the HD. As other cable may not support properly.
Enjoy
SQE
4/16/2009 3:06:21 AM • Western Digital... • Answered on Apr 16, 2009
750GB Western Digital HDD won't turn on.
hi.. try to Remove the drive from it's external case, and try a different hard drive. If that works, your drive is the problem. If it still doesn't work, the USB to IDE interface is the issue.
Try mounting the original IDE drive internally, and see if you can read it there. If not, you'll need to send it to a data recovery center...
thank u
2/9/2009 6:39:47 AM • Western Digital... • Answered on Feb 09, 2009
WD 120 Gig HD
There is usually only one light on the drive, which indicates that data is being read or written when the light is light.
1/19/2009 8:03:58 AM • Western Digital... • Answered on Jan 19, 2009
Cannot see WD 120 GB in my Computer
Sounds like the USB interface is working, but the physical drive is not. Remove the drive from it's external case, and try a different hard drive. If that works, your drive is the problem. If it still doesn't work, the USB to IDE interface is the issue.
9/17/2008 12:56:30 PM • Western Digital... • Answered on Sep 17, 2008
Disk boot failure, insert system disk and press enter
The drive should be set with jumpers or cable select to be primary master. Some pc & drive combinations don't like cable select, others insist on it. Try both, one at a time.
9/17/2008 12:46:15 PM • Western Digital... • Answered on Sep 17, 2008
2answers
Cannot access western digital 120gb hard drive
Please use Computer Management by clicking Start> Control Panel> Administrative Tools> Computer Management> Disk Management.
If your harddrive appear maybe you need to assigned drive letter then apply and right click then explore.
Please rate me SOLVED
9/8/2008 8:36:31 AM • Western Digital... • Answered on Sep 08, 2008
WD 120 GB 2.5" hdd not listed in my computer
I HAVE MY PROPERIETRY SOFTWARE WHICH I USE TO FORMAT ANY DISK OF ANY TYPE... AND MAKE ANY TYPE OF PARTITIONS LIKE ALL IN ONE PARTITIONING AND DISK MANAGMENT.
I HAVE STILL NOT REGISTERED AND TRADE MARKED IT. BUT I AM SUCCESFUL IN MY PRACTICE ON VARIUOS HARD DISK DISCOVERIES AND RECOVERIES .EVEN I CAN DO A FULL ZERO LEVEL FORMAT TO ANY HD.
CATCH ME AND REQUEST FIXYA TO ALLOW YOU TO SEND YOUR HDD OR ANY TYPE OF STORAGE MEDIA FOR RECOVERY AND SOLUTIONS. +0+9+3+2+1+1+0+1+7+1+7
7/25/2008 1:06:00 PM • Western Digital... • Answered on Jul 25, 2008
Western Digital (WDXB1200BBRNN) 120 GB Hard Drive Logo
34 questions posted
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Western Digital Computers & Internet
Most Popular Question
wrote zeros hard drive
  • Computers & Internet
