20 Most Recent Kenmore 5055, 50557 and 50558 Anti-Allergen Bags- 3 Pack Questions & Answers
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Kenmore 5055,... | Answered on Apr 02, 2014
It might sound very easy , but lack of power is usually the cause of a vacuum cleaner that is not working . Check that the vacuum cleaner is plugged into a working power outlet and that fuses and breakers don't need resetting. An activated thermal cut-out due to a blockage is the next most likely cause of the problem.
Tripped Circuit Breaker/ Blown Fuse
Check service panel for tripped breakers/blown fuses. If breaker is tripped, reset it. If fuse is blown, replace it. If vacuum cleaner is plugged in, make sure that the power button is in the off position before having to reset the breaker/changing fuse.
Kenmore Vacuums | Answered on Sep 06, 2020
The ends are cemented on. Have to be cut to remove. New ends are glued on.
Kenmore Vacuums | Answered on Aug 15, 2020
Some top covers are retained by coil springs. Releasing the springs frees up the cover to gain access yo the foot pedal.
Kenmore Vacuums | Answered on Jul 20, 2020
I just tried this trick from an Amazon review answer and it worked! I just turned the handle upset down, pressed the wand release button while the handle was in that position, and voila! The attachment came right out. Here's the Amazon quote I found via Google:
"Unplug the vacuum and remove the wand. If you cannot get your wand to release, try turning the handle over, and using gravity to allow the wand release switch to fall while you depress the wand release button and jiggle the wand in and out."
Kenmore Vacuums | Answered on Apr 26, 2020
The reset "button"may be defective.
Kenmore Vacuums | Answered on Apr 23, 2020
Have you checked the belt? The rollers are usually attached to the
belt
Kenmore Vacuums | Answered on Jan 05, 2020
You have to "help" the button depress sufficiently to allow the wand to release.
Kenmore Vacuums | Answered on Sep 18, 2019
I don't have one of these, but is it possible that the new, clean bag has not been installed properly or the cover is not completely in place? Just some things to double check. If all else fails, I suggest calling the manufacturer. (Kenmore is owned by Sears)
Kenmore Vacuums | Answered on Aug 10, 2019
I saw a number of fraudulent web sites pretending to have the manual when I performed a Google internet search.
Please contact Sears to request assistance so you are not deceived.
https://www.searspartsdirect.com/search?q=385-15752090
Kenmore Vacuums | Answered on Apr 05, 2019
SORRY NOT A CLUE AS NEVER HAD A BROKEN ONE PERSONALLY
Kenmore Vacuums | Answered on Mar 18, 2019
Kenmore 5055, 50557 and 50558 Anti-Allergen Bags- 3 Pack Logo
1 questions posted
Top Kenmore Vacuums Experts
Marvin
Marvin
Mike
Van Allen
Van Allen
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Vacuums
  • Kenmore Vacuums
Most Popular Question
burning smell kenmore 50558
  • Vacuums
