20 Most Recent
Electrolux Discovery/Genesis Vacuum Cleaner Replacement Filter 2 Pack Questions & Answers
Electrolux h5005
Can't find the question for the Electrolux vacuum cleaner H5005, but I have one of my own: Where can I get a wheel for this model?
Replace belt on Electrolux Epic 2500 SR Upright
1. Start by removing the screws that secure the bottom plate of your vacuum. 2. Once the bottom plate is removed, you will find the belt inside, as well as the belt pulley and drive wheels. 3. Disconnect the belt from the belt pulley. 4. Align the new belt over the belt pulley and drive wheels so that the teeth of the belt match up with the grooves on the pulley. 5. Wrap the belt around the pulley and drive wheels, and then reattach the belt to the pulley with the supplied clips. 6. Reassemble the vacuum and you're done!
Where can I find a manual for the Electrolux PowerPlus Z4471 cylinder vacuum cleaner?
You may be able to find a manual for your Electrolux PowerPlus Z4471 cylinder vacuum cleaner online or by contacting Electrolux directly. Here are a few suggestions for finding a manual:
- Search online for the make and model of your vacuum, along with the word "manual." You may be able to find a downloadable PDF of the manual or purchase a physical copy from a third-party seller.
- Check the manufacturer's website. Many manufacturers make manuals available for download or purchase on their websites.
- Contact the manufacturer directly. You may be able to request a copy of the manual from the manufacturer's customer service department.
Where can I find a rocker for my
You may be able to find a rocker for the on/off switch of your Electrolux Silverado 1505 vacuum at an Electrolux dealer or an authorized repair center. You may also be able to purchase a replacement rocker online from an retailer that specializes in vacuum parts and accessories. Here are a few suggestions for finding a replacement rocker:
- Search online for the make and model of your vacuum, along with the words "replacement rocker" or "on/off switch rocker." You may be able to find a compatible rocker from an online retailer that specializes in vacuum parts and accessories.
- Check the manufacturer's website. You may be able to purchase a replacement rocker directly from Electrolux or find a list of authorized dealers or repair centers where you can purchase one.
- Contact the manufacturer directly. You may be able to request a replacement rocker from Electrolux's customer service department or find a list of authorized dealers or repair centers where you can purchase one.
How do i get my brush roller to spin ?
Please check that all of your belts are still good (ie not stretched out, torn or otherwise worn). Also, please double check that you've cleaned all debris from the brush roll. You might need a tooth brush or a comb that you can throw out later. You might use shampoo to clean in. Then , please have the brush roll motor checked.
Thank you.
