20 Most Recent Summit Professional SPW1102 11 lbs. Front Load Washer - White Questions & Answers
motors don't hum unless there is a faulty start /run capacitor in the circuit
the hum can be from a faulty water control solenoid
could be a faulty program control board
call in a technician and get a quote
Summit... | Answered on Feb 15, 2016
I could not find a manual for your SPW2201SS, but I did find a manual for a SPW2200SS. (Look for clogged hoses, in and out!) Sadly it only lists three 'error codes' on Page 27 and they include: E10 E21 E31 Summit SPWD2201SS Washer download instruction manual pdf
Summit Washing... | Answered on Oct 28, 2018
ASK THE MANUFACTURER WE HAVE NO CLUE
Washing Machines | Answered 17 hours ago
Yes, programming knobs are supposed to turn. Unlikely to be the knob, unless it just spins. Some you have to push or pull out as a child safety feature.
Google
make model manual
or click Comment and I'll find it.
Washing Machines | Answered Yesterday
I suspect it isn't a washing machine fault - you need to provide more details.
There shouldn't be any mushrooms inside your MYSTERY device. I have a great recipe for baked stuffed Portobello mushrooms if you want it.
Google
make model manual
it sounds like you have a water leak and the pan that is under the machine has water in it. There is a sensor that prevents use when there is a leak
google
make model water leak sensor
Washing Machines | Answered 2 days ago
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Washing Machines | Answered 3 days ago
    Short cycling of a water pump which is defined at short cycling water pumps means that the water pump or "well pump" turns on and off too rapidly or too frequently when water is being run in the building. ... The most-common cause of pump short-cycling is loss of air in the water pressure tank.
    E02 After starting or during the functions of filtering or/and heating, the water flow sensors do not detect water flow.
    The 2 stopper caps have not been removed from inside the spa. ... Remove the filter set from inside the spa and push the filter or heat button.
    Washing Machines | Answered on May 30, 2020
    This is the first time I have heard of a washer under the Grundig label - hopefully they aren't as complex and over-engineered as their original products.
    Possible causes of no water in tub...
    Failed water inlet solenoid valve.
    Wiring fault.
    Programmer.
    Failed tub water level switch or blocked tube to the switch (if your washer uses a pressure switch to control level.
    Door switch or wiring.
    Washing Machines | Answered on May 27, 2020
    Does it make a sound while you set it to drain?
    If yes I'd check for a blockage within the drain system
    That error is a drain error and it could be something in the line that you cannot see when you looked at and cleaned the filter. Any articles of clothing that may be at the inlet of the pump could cause it, You are going to have to lay the unit down if it is a top loader, in order to see the hoses and check them. It could also be the pump has failed.
    DON'T LOOK ON FIXYA WE DO NOT HAVE PARTS
    Summit Professional SPW1102 11 lbs. Front Load Washer - White Logo
    2 questions posted
    Top Summit Washing Machines Experts
    ray gallant
    Dai Boyce
    Dai Boyce
     Russ Hill
    Russ Hill
    Are you a Summit Washing Machine Expert? Answer questions, earn points and help others
    View Most Popular
    • Summit Washing Machines
    Most Popular Question
    machine fill or run
    • Washing Machines
