20 Most Recent Kenmore Elite Washer 11023032100 Questions & Answers
Kenmore 80 series washer , model #92281100 is leaking when I use warm water
If it is only leaking when you use warm water it is likely a leak from the delivery side of the hot water inlet solenoid. The only way to check is to remove the top and look. https://www.google.com/search?q=Kenmore+80+series+washer+92281100+leaks ..
3/31/2024 6:32:15 PM • Kenmore Washing... • Answered on Mar 31, 2024
Replace lid switch on kenmore washing machine top load model #110.24962301
Thats a simple one to replace. Unplug unit. Take a putty knife and release clips that secure console to top. They are located on each front corner of console. Raise lid. Unplug harness from switch. Take ground screw out that is part of switch assembly. Release plastic tab that holds switch in place and remove switch. Install and snap into place new switch with lid open. Put ground screw back in place and plug harness back into place. Lower lid and then raise and listen for clicking noise. Put console back in place. That’s it.
3/11/2024 8:20:50 PM • Kenmore Washing... • Answered on Mar 11, 2024
Kenmore I own a Kenmore top-loading washing machine model 700S. The glass lid of my machine pops up from the back, and the rubber plug that holds it in place comes off.
If this is the model ('700S' is a series name), the lid is no longer available.https://www.searspartsdirect.com/model/3fpuvflk1q-000583/kenmore-elite-79629272000-washer-partsSo best fixes would be silicone and liquid metal epoxy as needed.https://www.google.com/search?q=kenmore+top-load+700s+lid+replacementI also found this, if the 'rubber plug' is the pivot on the back edge, you could make one from a dowel and fix with epoxy.https://www.searspartsdirect.com/product/59z4rap6tv-0026-795/id-afg72909503..
3/11/2024 8:19:56 PM • Kenmore Washing... • Answered on Mar 11, 2024
2answers
Kenmore filled up with water then quit working?
Question edited for clarity. 'then', a moment in time. 'than', a comparison between one thing and another. It depends on the model, but usually related to the lid lock. Also check the breaker. Why does my washer stop working after filling with water? If the Top Load Washer stops after filling with water, be sure to check the house circuit breaker/fuse as well as the outlet and plug. Washers should be plugged into their own separate, dedicated outlet. ..
2/22/2024 7:20:17 PM • Kenmore Washing... • Answered on Feb 22, 2024
Kenmore washer 110.20022013 stops after wash cycle
Usually it's the lid switch..When you open the lip look straight down usually..When you close the lid it inserts a small plastic piece that goes into the hole telling the washer the lids down..If it broke it will make the washer stop mid cycle..You can stick a wooden (only made of wood) into the hole and sometimes it will start to work..Then you know that's the problem and just get your model number of the washer and replace it..Hope this helps
2/18/2024 2:31:59 AM • Kenmore Washing... • Answered on Feb 18, 2024
How do I remove the from a kenmore 80 series model 110.28803890? Something special may have come out of a pocket during washing.
You start with under the agitator, then the filter, then the pump, then the hoses at the base of the drum and then everything else. Then you find nothing and remember you took it out of your pocket and put it in........ ..
1/31/2024 6:49:34 AM • Kenmore Washing... • Answered on Jan 31, 2024
Kenmore Washer 70 series. How to put the cabinet back into place? I SOLVED IT! See my last comment!
You normally start from the back. It will be the opposite or the videos.
HOw to remove back from kenmore series 70 washing ...
JustAnswer https://www.justanswer.com > Appliance Repair Mar 6, 2012 - Below is a link to a video that shows you how to take the cabinet off the washer. CLICK HERE. 1 answer · Top answer: no problem and I wish you only the best of luck. If you're handy this should re ..
1/29/2024 7:18:48 PM • Kenmore Washing... • Answered on Jan 29, 2024
Kenmore 98702 center won't drain when using cold water cycle.
Troubleshooting: Check the drain hose: Ensure that the drain hose is not clogged or kinked. If it is, straighten it out and remove any blockages. Inspect the drain pump: Check the drain pump for any debris or foreign objects that may be blocking it. Clean it out if necessary. Check the lid switch: Ensure that the lid switch is functioning properly. If it is faulty, it may prevent the machine from starting the drain cycle. Check the waste hose: Ensure that the waste hose is not clogged. A clogged waste hose can prevent water from flowing out of the machine. If this troubleshooting does not work, you may have to turn to professional assistance from a repairman.
1/26/2024 9:04:43 PM • Kenmore Washing... • Answered on Jan 26, 2024
Kenmore washing machine. When I hit the start button,the washer spits out about 4 onces of water and then shuts off. This happens whether I use hot or cold water.
For some reason, it is failing the self diagnostic tests. You need a service engineer, because the reason is likely the main control board. For that reason you need the correct diagnosis and warranty on the part and the work performed. This is not a simple fix. If the machine is old it may be prudent to just replace it.
1/17/2024 10:13:58 PM • Kenmore Washing... • Answered on Jan 17, 2024
What is tub capacity for Kenmore 41794702300
The tub capacity of the Kenmore 41794702300 laundry center is 3.9 cubic feet. This means that the washer can hold up to 20 pounds of laundry.
1/15/2024 10:19:27 PM • Kenmore Washing... • Answered on Jan 15, 2024
Kenmore Oasis washer model 110. 27072603 is extremely loud like a jet engine when in the spin cycle. No grinding or metalic sound, just a loud whirring that sounds like an engine at very high RPM.
The electric motor turns at a very high rate and as the brushes grip the commutator, they whine. The more weight in the machine, the more noise. Normal.
1/12/2024 7:18:48 PM • Kenmore Washing... • Answered on Jan 12, 2024
Kenmore 70 series not draining
If your Kenmore 70 series washing machine is not draining, check the drain hose for clogs or kinks. Ensure the pump is functioning, and inspect the lid switch for any issues. If problems persist, consider consulting the user manual or contacting Kenmore customer support for further assistance.
1/8/2024 12:52:10 PM • Kenmore Washing... • Answered on Jan 08, 2024
Kenmore F35 error. Unit on washer drum that connects to the water level sensor has a pin hole and is leaking.
If you find a tear in the hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. Jul 21, 2015
What is the error code F-35 - Kenmore Elite HE3 Washing ...
Replace the parts, or block the hole with waterproof epoxy putty.
Model # 11047789701 Official Kenmore Elite washer
Sears PartsDirect https://www.searspartsdirect.com > model > kenmore-e... Here are the diagrams and repair parts for Official Kenmore Elite 11047789701 washer, as well as links to manuals and error code tables, if available. Continue . ..
1/4/2024 7:06:12 PM • Kenmore Washing... • Answered on Jan 04, 2024
Kenmore 70 Series Washing Machine Problem
You were answering an AI Bot Chat GPT4 generated Answer, so we delete them. Well done for fixing it Testimonial: "Thank you just seeing this now. A couple of days ago I tore it all apart again. I checked the clutch and everything was fine. To my disbelief the coupler that I replaced 2 months, separated from the metal insert. So, I purchased one that was all plastic. I got everything working but it was shaking really bad on the spin cycle. I happened to see some stating to check the skate plate and sure enough it wasn't lined up. Everything is working great but there's still a slight vibration on the spin cycle. I think I will replace the 3 plastic pieces under the skate plate. All the springs look great so still not sure why it's unbalanced when spinning out." ..
12/30/2023 8:50:11 PM • Kenmore Washing... • Answered on Dec 30, 2023
2answers
Which is the switch for the kenmore 700s he top load washer for the lid lock trying to bypass it because it broke
check with sears link below you need model number WWW.SEARSPARTSDIRECT.COM
12/20/2023 2:38:15 PM • Kenmore Washing... • Answered on Dec 20, 2023
Kenmore Elite Washer 11023032100 Logo
7 questions posted
Alexander
vince
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
timer all out wack when go start cycle
  • Washing Machines
