20 Most Recent FACTORY AC PARTS Limit Switch Double Pole L150 Direct Replacement For Rheem Ruud Weatherking Oem Part 47-20045-02 Questions & Answers
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
FACTORY AC PARTS... | Answered on Jan 03, 2016
one of these would probably work for you
https://www.homedepot.com/p/Husky-24-in-Lighted-Mechanical-Pickup-Tool-70396H/206264355?source=shoppingads&locale=en-US&mtc=Shopping-Husky_Hand_tools_BT3_Smart_Shopping&cm_mmc=Shopping-Husky_Hand_tools_BT3_Smart_Shopping-71700000074196197-58700006428347897-92700058269432290&gclid=Cj0KCQiA3Y-ABhCnARIsAKYDH7v2O-KwNy6CqfukELgD2NG4TC0GShENPGBINPx414jIBEkFE7F6jTkaAtQcEALw_wcB&gclsrc=aw.ds
Dryers | Answered 2 days ago
Common dryer problems for the dryer to not work are a faulty door switch or and start switch and control problems such as a broken dryer timer or faulty electronic control board: Issues with the door switch can stop the dryer from starting or turning on . A blown thermal fuse most often prevents an electric dryer from starting up and needs to be replaced and repaired from a person that fixes major appliances.
Dryers | Answered on Jan 14, 2021
Disconnect the power overnight. It SHOULD reset.
Dryers | Answered on Jan 12, 2021
Time to call service personel.
Dryers | Answered on Jan 11, 2021
Perhaps the element is open circuit - as voltage is present, current should be flowing and if current flows through a heating element if should get hot...
Dryers | Answered on Jan 10, 2021
Some dryers have a 'no heat' setting. Is it new? Did you read the manual? Did it work before?
Click 'Comment' under my post to answer.
Google
make model light flashing
Impossible to guess questions like this without full
make model (what it is)
Dryers | Answered on Jan 09, 2021
Hi
many harbor breeze remotes have a learn button which replaces the old dipswitch settings.
If you have an older Harbor Breeze ceiling fan then you will need to ensure the dipswitch settings on your receiver and remote are in sync. This article here: Harbor Breeze Ceiling Fan Remote will show you how to do this. https://hamptonlightingadvice.com/harbor-breeze-ceiling-fan-remote-not-working/
Dryers | Answered on Jan 08, 2021
'it' makes it a mystery machine!
all questions must have full
You can find Electrolux E64 error code information here
https://appliancerepairinfo.com/electrolux-dryer-error-codes/
Dryers | Answered on Dec 31, 2020
You can find info on the Whirlpool F30 error code here
https://appliancerepairinfo.com/whirlpool-dryer-error-codes/
Dryers | Answered on Dec 30, 2020
remove the front half of the protector shroud
left hand thread for the fan center and pull off
Dryers | Answered on Dec 29, 2020
Looks like a Home Depot fan. Where are the three wires located that aren't connected?
Sir,I think you need a paper towel and a compressed air probably a blower.next open humidifier and clean with towel and now the air blower for the blades
Dryers | Answered on Dec 27, 2020
FACTORY AC PARTS Limit Switch Double Pole L150 Direct Replacement For Rheem Ruud Weatherking Oem Part 47-20045-02 Logo
1 questions posted
Top FACTORY AC PARTS Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a FACTORY AC PARTS Dryer Expert? Answer questions, earn points and help others
View Most Popular
  • FACTORY AC PARTS Dryers
Most Popular Question
every limit switch switched in
  • Dryers
