20 Most Recent Admiral Dryer. 6.5 cu. ft. Electric Dryer in White AED4675YQ Questions & Answers
What type of power cord do i need?
An electric dryer has an opening in the back, older units use a three prong cord, there will be three posts to attach cord, newer units have four prong cords, Bought separately. there will be four posts to attach, double grounded cord.
11/11/2017 2:19:38 AM • Admiral Dryer.... • Answered on Nov 11, 2017
I turned the knob for 45 min drying time and it was still running 3 hours later and no heat now.
Very likely you now have 2 problems. First, the timer has "failed", and is not advancing. That should require a new or used timer. Those are available many places, such as "Sears Parts Direct" (this web site will give you the part number of the part you will need), Amazon, or e-bay. Next, you may or may not need some part that will let the dryer heat. There could be one of about 6 or 8 parts that have failed, each one will need to be checked with an electric meter to find that faulty one. Again, "Sears Parts Direct" will help you with the part number when you need a part. God bless your efforts.
3/21/2016 5:17:31 PM • Admiral Dryer.... • Answered on Mar 21, 2016
2answers
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
4/13/2015 4:49:24 PM • Admiral Dryer.... • Answered on Apr 13, 2015
Not heating
element or thurmostats...you will need a meter to test each.......or just buy completr kit of element and stats..................good luck
4/15/2014 6:18:47 PM • Admiral Dryer.... • Answered on Apr 15, 2014
What's wrong with my dryer
belt is probebly slipping on the motor........cheers
1/31/2014 12:09:51 AM • Admiral Dryer.... • Answered on Jan 31, 2014
Belt tensioner and belt came off
Unplug, remove the screws at lint trap, do not drop in trap! Press in on the clips at the front edge approximately and inch in from each side, lift top. Remove the screws on the inside of front pane;, unplug door switch, tilt front forward and lift the front off. The idler pulley (what you are calling tensioner ) slips in the slots in front of the motor. This link has a picture of how the belt is installed I wrote this article a while ago How Replace The Belt on Your Whirlpool Dryer
1/30/2014 10:53:37 AM • Admiral Dryer.... • Answered on Jan 30, 2014
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
1/2/2014 10:25:07 PM • Admiral Dryer.... • Answered on Jan 02, 2014
0answers
I have a admiral aed4475tq less than a year old and it just stoped and wont restart
Does the motor hum when you try to start it in the above mentioned manner? Does the door switch click when you push and release it?
2/22/2013 11:40:56 PM • Admiral Dryer.... • Answered on Feb 22, 2013
0answers
My dryer stop working. The light inside has gone out. However, when you turn the dial to a setting, you can still hear the dryer ticking. Now what? I've check the house's circuit breakers to s
Have you tested the voltage at the dryer terminal block? Left stud to the rht stud should read 240 vac. both outside to center should be 120vac. Follow the path of electricity on the diagram. thermals fuse open? Wires cut to door switch? Being that the timer drive motor is humming ,you are getting at least 120vac to the dryer ,but possible not 240vac. Model# ??
4/28/2019 12:43:16 PM • Admiral Dryers • Answered on Apr 28, 2019
Admiral dryer not heating
I have no idea what dryer your talking about due to the fact that there is no model number posted! most dryers have two thermal fuses which can be found in the diagram. The timer can be at fault with a contact not closing. Diagram again! Motor switch could be at fault, closes heat circuit after motor starts. Diagram again! dDont throw parts at it until you verify the cause, you have spent enough already.
4/28/2019 12:30:09 PM • Admiral Dryers • Answered on Apr 28, 2019
Admiral Capacity Plus Dryer how maby amps should it use on low heat and how many on high heat
Same with either. Low heat just means element doesn’t stay on as long as on high.
10/3/2018 1:30:47 AM • Admiral Dryers • Answered on Oct 03, 2018
How to bypass upper and lower thermostat on a admiral dryer
Why would you want to bypass a thermostat? Without it the unit will just continue to heat until it burns out
6/20/2018 6:28:17 PM • Admiral Dryers • Answered on Jun 20, 2018
Admiral Dryer. 6.5 cu. ft. Electric Dryer in White AED4675YQ Logo
17 questions posted
Top Admiral Dryers Experts
Dan Webster
Dan Webster
john h
Are you an Admiral Dryer Expert? Answer questions, earn points and help others
View Most Popular
Admiral Dryers
  • Admiral Dryers
Most Popular Question
making mywhirlpool admiral electric
  • Dryers
