20 Most Recent Singer 7469Q - Confidence Quilter Machine Questions & Answers
Confidence Quilter 7469Q how do I load the bobbin?
Are you trying to wind the bobbin or just dropping it into the bobbin case and bring up the thread? To wind the bobbin, place the spool on the pin and secure it with the spool pin cap. Pull the thread and pull it through the thread guides. The first guide is accessed by going around it and then pulling the thread under it. Go under the adjacent guide and then wrap the thread counter-clockwise (when facing the front of the machine) under the next guide to bring the thread back to the bobbin winder. Hold the bobbin with the hole up and pull the thread through that hole. Push the bobbin winder shaft to the far left and place the bobbin on the winder pin. Push the bobbin and winder shaft to the right until it clicks. Hold the thread and start the sewing machine. It will automatically stop when the bobbin is full. Move the bobbin winder shaft and bobbin to the left and take the bobbin off. Then cut the thread to separate the bobbin from the spool thread. To put the bobbin into the bobbin case and bring up the thread: Make sure that the needle is in the highest position (use the handwheel). Then open the bobbin cover by pressing the release lever to the right and then lifting up the cover. Hold the bobbin with the hole up so that the bobbin turns counter-clockwise when you pull the thread. Drop the bobbin into the bobbin case. Pull the thread into the slot just to the left of the bottom center (6 o'clock on a 12-hour analog clock), of the bobbin case. Place a finger on top of the bobbin and pull the thread to the left until it stops at the slot between the 7-8 o'clock position. Now pull the thread along the groove in the needle plate to the thread cutter. Replace the clear bobbin cover. The thread should be pulled up by the needle thread without any additional effort. (If it isn't, there may be a problem with the bobbin case or race.) Singer has the manual for the 7469Q on their site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/549_7469_efs.pdf . Winding the bobbin is on page 16; threading the bobbin at the bobbin case is on page 18. These pages have good pictures to go with the descriptions. I hope this helps. Cindy Wells
9/12/2016 10:58:10 PM • Singer 7469Q -... • Answered on Sep 12, 2016
Changing belt????
Motor Belt, Singer #087263 below is a link to singer support and you can apply for instutions press the helpful button 7469Q CONFIDENCE QUILTER
1/31/2016 5:44:11 PM • Singer 7469Q -... • Answered on Jan 31, 2016
0answers
I need the instruction book/manual
Contact your local Singer Dealer, Or look on Singer Web Site
3/11/2015 11:41:26 AM • Singer 7469Q -... • Answered on Mar 11, 2015
0answers
Singer 7469q
Be the first to answer 11/11/2013 4:56:50 PM • Singer 7469Q -... • Posted on Nov 11, 2013Be the first to answer
I was reversing and the machine just stopped...I have unplugged and replugged both the machine and the foot pedal. I have unthreaded and rethreaded the machine. Any suggestions?
test the power cord for open or faulty 2) loose wires from the power cord to the foot pedal3) foot pedal switch open or faulty, test the wires from loose or breake wires and repair3) motor need repair , brush, condensator, centrifugal switch. etcGod bless you
1/25/2013 8:03:29 PM • Singer 7469Q -... • Answered on Jan 25, 2013
Circuit diagram for ESP2 singer steam press
I do not have access to specific circuit diagrams for the ESP2 Singer Steam Press. However, I can provide some general information that may be helpful. The ESP2 Singer Steam Press operates by using an electric heating element to heat a water reservoir, which produces steam to press clothes and fabrics. The electrical circuitry of the steam press includes a power switch, heating element, thermostat, thermal fuse, and indicator lights. The power switch controls the flow of electricity to the steam press, allowing the user to turn it on and off. The heating element heats up the water in the reservoir, producing steam that is released through a pressing plate. The thermostat controls the temperature of the heating element, ensuring that the water is heated to the desired temperature. The thermal fuse acts as a safety device, preventing the steam press from overheating and potentially causing a fire. Finally, the indicator lights inform the user of the steam press's current operating status, such as whether it is heating up or ready to use. If you're experiencing issues with your ESP2 Singer Steam Press, it's recommended that you consult the user manual or contact a qualified technician for assistance. Modifying or repairing electrical equipment without proper knowledge or training can be dangerous and may cause injury or damage to the equipment.
2/26/2023 5:08:30 AM • Singer Irons • Answered on Feb 26, 2023
My singer iron has no steam
cheaper to replace it .. than fix it you might try a descale
7/1/2016 9:01:07 AM • Singer Irons • Answered on Jul 01, 2016
Singer 7469Q - Confidence Quilter Machine Logo
27 questions posted
Top Singer Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Singer Iron Expert? Answer questions, earn points and help others
View Most Popular
Singer Irons
  • Singer Irons
Most Popular Question
confidence quilter 7469q load bobbin
  • Irons
