20 Most Recent Vitamix 36000 Work Top Blender Questions & Answers
My Vitamix 3600 plus has same problem. Result of detachment of rubber coupling between lower splined socket from blade shaft. This is a tough rubber molding that takes tremendous punishment through years of smoothies. Mine showed some rust on the bottom of the blade shaft, where it parted. I tried gluing back together with super glue and tried to eyeball it. Of course it was off by a few degrees. When I reassembled and turned it on, what a racket of vibration! But it held. Amazing. Obviously not good to go though. So I took assembly all apart and redid it, chucking the shaft and the lower nut in the lathe. This time, all true on axis. Glue held for about a week. Right now I am regluing, this time with epoxy. We'll see how it holds up. And meanwhilst, I'm researching replacement parts! I'm not too optimistic about the epoxy.
Vitamix 36000... | Answered on Sep 22, 2016
Talk to manufacturer they should be able to help.
Vitamix Blenders | Answered on Jul 17, 2019
Check the black driving clutch on the top of the motor that engages with the other clutch half on the base of the blender jug. The fault should be there, normally it will be the motor part.
Vitamix Blenders | Answered on Feb 03, 2019
If you ask which Best Vitamix model is the finest this year, certainly I would recommend going through this guide to know about which Best Vitamix blender are actually market leaders. More to follow ...
10 Best Vitamix Blender, see Reviews every single Vitamix Vitamix 5200, Vitamix 7500, Vitamix 5300, Vitamix 750, Vitamix 5000, Vitamix 6300 Vitamix 6500, Vitamix 780, Vitamix E310, Vitamix S55, Vitamix Professional Series 750,
Read more Vitamix Vs Other Brend Comparison Blendtec vs Vitamix, Vitamix vs Ninja, Vitamix vs Nutribullet.
Also See Comparison Vitamix 5200 vs 5300, Vitamix 5300 vs 7500, Vitamix 5200 vs 7500, Vitamix 7500 vs 750, Vitamix 6500 vs 7500, Vitamix 5300 vs 6500,
If you want to Read Best Blender Reviews you can visit The Electric Blender Website.
Vitamix Blenders | Answered on Aug 26, 2018
10 Best Vitamix Blender , see Reviews every single Vitamix Vitamix 5200 , Vitamix 7500 , Vitamix 5300 , Vitamix 750 , Vitamix 5000 , Vitamix 6300 Vitamix 6500 , Vitamix 780 , Vitamix E310 , Vitamix S55 , Vitamix Professional Series 750 ,
Read more Vitamix Vs Other Brend Comparison Blendtec vs Vitamix , Vitamix vs Ninja , Vitamix vs Nutribullet .
Also See Comparison Vitamix 5200 vs 5300 , Vitamix 5300 vs 7500 , Vitamix 5200 vs 7500 , Vitamix 7500 vs 750 , Vitamix 6500 vs 7500 , Vitamix 5300 vs 6500 ,
What has worked very well for me in the past in similar situations (not with kitchen appliances but any older item needing a part) is find people selling the item or parts for the item on eBay, and then messaging them asking if they have a source for whatever it is I am looking for.
Almost always this leads to what I need, whether it is for a camera or an old watch or a vintage computer or whatever.
Messaging through eBay is easy, fast, and free.
Simply type Vitamix 4000 in the Search box, and get the listings displayed, and then click on Contact Seller.
eBay will send the message, and notify you when there is a reply.
Some models had a weakness with the variable resistance in the rotary switch but your description sounds more like the main PCB or even the motor both of which are very expensive parts to replace.
Vitamix Blenders | Answered on Jun 15, 2018
there is a wrench (by Vitamix) for under $10. you can get it from amazon. it makes the job of removing a blade assembly much easier.
Vitamix Blenders | Answered on Jan 30, 2018
not sure if this link will help you out but have a look.
Vitamix MP is not turning Google Search
Vitamix Blenders | Answered on Oct 30, 2017
Try Googling (vitamix)(5000)(manual) without parens.
Vitamix Blenders | Answered on Sep 13, 2017
Vitamix 36000 Work Top Blender Logo
12 questions posted
Top Vitamix Blenders Experts
Marvin
Marvin
Ross Keen
Lawrence Oravetz
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
View Most Popular
Vitamix Blenders
  • Vitamix Blenders
Most Popular Question
blade not spinning
  • Blenders
