20 Most Recent
Essick Air MA1201 Moist Air Whole House Humidifier Questions & Answers
Clean the fan blades
Don't use a hose, it will rust the motor and bearings.
if the blades are metal, and the unit is detached from the furnace. Try carburator cleaner or brake cleaner - out doors away from flames. Also, rotate so no solvents get to the bearings and wash away he lubricants. The solvent evaporates quickly but it will take a minute so don't be too impatient to get to the next blade.
If they are just dusty, and you don't want to dismount the unit, try some canned air - office stores carry this for cleaning keyboards and such. To get a really good stream, turn the can upside down and spray. The liquid propellant will come out and makes a really good cleaner. It will be cold cold cold as it evaporates and some ice will form if the humidity is high enough.
Effectiveness will depend on what is causing the dust to stick to the blades - oil film, soot from wood/coil/fuel oil and cigarette smoke are difficult.
How do I fix the fan on my D46 720 humidifier?
Working on line voltages without safety precautions and experience may cause injury and electric shock.
Check the switch and connecting wires from mains to fan motor. Similarly check there is no obstacles restricting to move fins. Usually fan motors are heavy duty motors and rarely become defective.
New filter, not running and leaking all over
www.amazon.com/
Essick-
Air...
Humidifier/.../B0000D...
Amazon.com, Inc.Essick Air 821-000 Digital Control Evaporative Console Humidifier ... Holds 6 gallons and will dump 6 gallons in to the air over a 24 hour period, which ... a pain to fill, eventually leak, or come defective from the factory (holes on seams). ... We left itrunning all night, and barely any water had evaporated by the next morning.
www.amazon.com/821...
Humidifier/.../B0000D8EJZ?...
Amazon.com, Inc.Essick Air 821-000 Digital Control Evaporative Console Humidifier ... So although notas dry as the northeast, it gets dry when the temps go down. ..... Had this humidifierfor less than three months and it started leaking all over my hard wood ...
