20 Most Recent Uvonair Corona Discharge In-Line Duct Ozonator 10 Questions & Answers
Ionic Pro Platinum TA750 Air Purifier. It will not turn on?
Question edited for clarity and toss in some CAPS. Question moved from Televisions category. Contact their Support for a warranty repair. https://www.envion.com/en/ta750 ..
12/12/2023 5:16:43 AM • Air Purifiers • Answered on Dec 12, 2023
I have an Afloia Air Purifier. The red light keeps blinking?
Question edited for clarity, dreadful spelling and typos. :>D Question moved from Televisions to Air Purifiers. Your air filter is dirty and needs cleaning.
Afloia Air Purifier Blinking Red - Repair, Care and ...
https://plentifulair.com > afloia-air-purifier-blinking-red... A flashing red light in all Afloia air purifiers indicates that the air filter needs to be replaced. Typically, in these air purifiers, the red light turns on ... ‎Why is My Afloia Air Purifier... · ‎How to Replace the Air Filter in... ..
11/7/2023 2:12:50 PM • Air Purifiers • Answered on Nov 07, 2023
Lost remote can I download one or an app for it please.
Question edited for clarity. Question moved from Cars and Trucks. From the maker https://www.google.com/search?q=Fresh+Air+by+Ecoquest+replacement+remote ..
11/7/2023 5:38:27 AM • Air Purifiers • Answered on Nov 07, 2023
My 20w aspectek bug zapper has stopped working, both bulbs off
Turn off the power button and Unplug the bug zapper. Turn off and Unplug Discharge Bent down and Remove Rotate and Replace the bulbs
8/27/2023 12:59:29 PM • Air Purifiers • Answered on Aug 27, 2023
What can I do to troubleshoot fuse blowing each time I turn on sanitizer - Breeze AT by EcoQuest
breaker blows or internal fuse ----either way need a multi meter to test for short
6/20/2023 1:21:36 PM • Air Purifiers • Answered on Jun 20, 2023
Rainmate Air Purifier. Why does my Rainmate not mist?
Question edited for clarity and correct maker name, plus (what it is). Question moved from Cars and Trucks. Usually just need cleaning and descaling
Cleaning Tips
Rainbow System https://rainbowsystem.com > Support You can even fill the Sprayer with ordinary household water and use it to mist your houseplants or clean your screen windows.
The Rainbow Rainmate: Does It Really Work?
GroundWaterGovernance.org https://www.groundwatergovernance.org > does-the-ra... Mar 13, 2022 - The simplest solution appears to be to change the water on a regular basis if possible. A home air purifier can be used as an aromatherapy ...
6/8/2023 3:47:31 PM • Air Purifiers • Answered on Jun 08, 2023
I need UV replacement BULB , I cant find one online
There are a few things you can try if you're having trouble finding a replacement UV bulb for your device online. One option is to check the manufacturer's website to see if they sell replacement bulbs directly. Many companies will also list authorized resellers on their website, so you may be able to find a replacement bulb from a trusted third-party seller. Another option is to try searching for the bulb using the model number of your device. This will help ensure that you're getting a replacement bulb that is specifically designed to work with your device. You can also try searching for the bulb using keywords related to the device, such as "UV water purifier bulb" or "UV air purifier bulb." If you still can't find the right replacement bulb, you may want to consider contacting the manufacturer directly to inquire about replacement options. They may be able to provide you with the information you need or point you in the direction of a trusted reseller. If online search not working you can try a local store that sell electronic part, Home improvement stores that carry a variety of lighting options may be able to help you find the UV bulb you need. Please do let me know the model number or application the UV light is used for, so that i could provide specific recommendations.
1/10/2023 4:58:20 PM • Air Purifiers • Answered on Jan 10, 2023
Filter red light flashing. I cleaned filter
Switch it off, count to 50, switch back on. 'make model (what it is)' in all questions, first 3 words please.
11/20/2022 7:31:43 PM • Air Purifiers • Answered on Nov 20, 2022
4answers
Lumipure AP-74 manual needed
hold in the power button for approx 5 seconds
11/4/2022 9:19:34 AM • Air Purifiers • Answered on Nov 04, 2022
5answers
Should I color my hair purple?
The Purple color that you will colored is amazing.Angel Brazilian Virgin Hair Online Store will supply you high quality hair with best price. The hair extension you can buy in our store in purple color.that color is good.A Brazilian weave, also referred to as a Brazilian wave, utilizes 100-percent virgin Brazilian hair to create a soft, wavy style. A stylist can apply Brazilian hair in any weave technique you prefer, allowing you the freedom of choice. However, when a stylist states that she offers a Brazilian weave, she may also be referring to a technique known as the Brazilian knot, where the extension is bound to the hair in small sections using an elastic thread. Taking care of a Brazilian weave is similar to any other human hair weave, but there are a few minor considerations when taking care of Brazilian hair and the Brazilian knot in particular. For details welcome to visit our website www.milkywayhairweft.com www.amazon.com/shops/MoonAngelHair
10/17/2022 11:22:12 AM • Air Purifiers • Answered on Oct 17, 2022
4answers
What is the best method for purifying water?
depends on where you are and when you want the water treated. for camping and hiking , water purification tablets are quick and easy methods and one of the best ( used by the armed forces ) if you want it for home use running the water through a ceramic filter then through an ultra-violet purifier will get rid of all the bugs for larger volumes an osmosis purifying system as used by the water treatment works in council water supplies is best so you need to specific as to when you want the water pure. boiling water is ineffective as it concentrates the bugs and doesn;t kill them all, however distilling water by boiling off and collecting the steam back to water separates the bugs
9/7/2022 11:55:04 AM • Air Purifiers • Answered on Sep 07, 2022
2answers
WINIX 5500-2 4-Stage Air Purifier with PlasmaWave® Technology. I changed the filters but now the white fan light flashing on two fans and won't stop. I did reset.
Resetting Filter Life: After replacing your True HEPA Filter, place the Pre-Filter back in and close the Front Panel. While the unit is on, hold the Filter Reset Button for at least 5 seconds until you hear the beep. After the beep, the Filter Replacement Indicator will disappear. Your Winix True HEPA is now reset you can call (877) 699-4649 for more help
8/31/2022 6:08:44 PM • Air Purifiers • Answered on Aug 31, 2022
My Breathe Fresh, YD-700A, turns ON and ... HIGH, EFFICIENT, STERILIZER and Anion are lit up and will not turn OFF. What does this mean? and is it OK to run in low mode
There is always the possibility that the main control board has failed in that unit. The unit generates very high voltage and negative charges that leave the grid to trap small particles. With that in mind the board can accumulate a static charge and be ruined. Can you run it? I would not. There are cases where units similar to yours have caused fires.
8/23/2022 10:08:01 PM • Air Purifiers • Answered on Aug 23, 2022
Thera Pure. Why won't it turn on?
My THERAPURE wouldn't turn on either. I got it when my mom upgraded but could never get it to power on. I came here for help. I figured it out myself. The filter was put in upside down after it was cleaned. Odd that it even fit. I flipped it, plugged it in, and it turned right on! Good luck. Hope your fixes are all as easy as mine!
7/11/2022 8:51:16 PM • Air Purifiers • Answered on Jul 11, 2022
3answers
Should my 1.5 acre stinger bug zapper zap when I plug it up
Intuitively, I glean it zaps when you turn it on only if you are a bug. Zapping is caused by the bug encountering the zapper. Otherwise, it would zap you even if you were not a big bug, simply because you were in close proximity.
7/7/2022 8:39:55 PM • Air Purifiers • Answered on Jul 07, 2022
2answers
Does it really purify,drain and restore your entire lymphatic system?
nothing does that if it was possible then there would be no cancers in the lymphatic nodes and cancer would be obsolete as all that would have to done is to drain the nodes just good but deceptive advertising
7/6/2022 7:40:01 AM • Air Purifiers • Answered on Jul 06, 2022
2answers
I have a COWAY AP-1512HHW air purifier and it turns off after operating for less than a minute, and the Air Quality light continuously blinks blue. What is wrong? How can I resolve?
reload windows and reboot.(scrc off)you posted a air purifier to computer repair help forum, why? .the unit needs to be cleaned first. the manual covers that in all purifiers.the blue light means ? quality of air, but if it is dirty (it self,) then this sensor device it lies to you, so it and the main are dirty. page 10 covers sensor.cleaning it is an endless task, wash wear repeat. (pun) but real.page 10 to 12 is clear, see the vacuum used? every 2 weeks it states.free:https://www.manualslib.com/manual/922271/Coway-Ap-1512hh.html?page=2#manuali will try to move this post to HVAC systems. it is not a computer, it is for Air conditioning , really.
7/1/2022 11:24:24 AM • Air Purifiers • Answered on Jul 01, 2022
2answers
Rewire Stinger UV40 Bug zapper to use a screw in bulb.
You would have to pull the ballast transformer out. Pull the light fitting out. Fit a new socket. Run the mains wires that went the ballast transformer to the new socket.
5/11/2022 5:20:28 PM • Air Purifiers • Answered on May 11, 2022
Uvonair Corona Discharge In-Line Duct Ozonator 10 Logo
0 questions posted
Top Uvonair Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Uvonair Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Uvonair Air Purifiers
Most Popular Question
new comfort ca3500 air purifier heat
  • Air Purifiers
