20 Most Recent Hifonics BX1000D Car Audio Amplifier Questions & Answers
Have you tried turning up the vol/gain control? Are all the switches on the amp set for full spectrum output? Are you sure you are using the RCA input and not the RCA output jacks (if it has such)? Check all the switches to be sure they are in the "most default" position. Something you might try, is to make a jumper wire to temporarily jump from the audio input ground to the power supply (chassis of car) ground. If this makes it work then you have a input ground problem in the amp. Good luck. P.S. As for epoxying the trace down on your other amp. If the foil is still in good condition then it should be ok to epoxy it down. If it needs some "help" then do that first, then epoxy.
Hifonics BX1000D... | Answered on Feb 17, 2007
Your amp could still have a short not allowing it to provide audio to your speakers. Confirm that your speakers are not blown. Use VOM meter to confirm the ohm rating.
Hifonics Car... | Answered on Feb 04, 2019
This means that the remote wire is 0V instead of 12V. Try to connect it over from the 12V to check if it powers on.
Hifonics Car... | Answered on Jan 15, 2019
MKe sure you have 12 vole coming from m your remote will re after your system starts up.
Hifonics Car... | Answered on Dec 03, 2017
By your description allegedly 2 x 100watt. So 200w music power.
Hifonics Car... | Answered on Nov 19, 2017
Run a dual 2ohm sub on it. Bridged parallel. That will give you your max. 600rms/1200max
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Hifonics Car... | Answered on Oct 04, 2017
There is nada wrong with your preamp and changing it will accomplish nothing. If your channels are allegedly clipping it is due to the fact that it is being over driven. A bad preamp could not over drive your amp!
Have to be careful with tone controls at high levels. Every 3db increase compels amp to double power at that frequency. So if you are blasting at 2000 watts and you boost a control by that amount, your amp will put out 4000 watts and clip. If plus 6db then it is 8000 watts!
Hifonics Car... | Answered on Jun 20, 2017
Overdriving the output can cause it to go into protect mode. You will not be able to restore normal operation until failed components are replaced.
Hifonics Car... | Answered on Jun 06, 2017
Some amps will not power up internally if u donot have remote wire. Also if u connect power then remote wire it will not power up until u reconnect in correct order. But if all that is ok. Than u have a bad amp
Hifonics Car... | Answered on Mar 11, 2017
Your amplifier may have experienced circuit failure other than a dead short that still allows power to be applied
Hifonics Car... | Answered on Dec 05, 2016
Hifonics BX1000D Car Audio Amplifier Logo
Popular Tags
1 questions posted
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hifonics Car Audio & Video
Most Popular Question
no output
  • Car Audio & Video
