20 Most Recent JBL GTO75.4 Car Audio Amplifier Questions & Answers
2answers
My amp keep jumping in an out of protect
Something is fried.
9/22/2014 5:05:33 AM • JBL GTO75.4 Car... • Answered on Sep 22, 2014
My jbl gto75.4 red light
check the cord from deck to amp when you trun on the deck it should go from red to green some of amps you do need to run a blue wire from deck to amp. that the remot wire.. so you don,t need it going bysingle from the rca cable... I hope this help you out ty
7/8/2013 11:00:30 PM • JBL GTO75.4 Car... • Answered on Jul 08, 2013
My amp
Check your speakers with an ohm meter. They should have some resistance but not totally shorted. Its prob the amp that got fried. Connect the amp to the battery with no speakers attached to it if the protection light still comes on then the amp is blown.
If the amp is blown you can send it to people on ebay and get it fixed pretty cheap. Good luck!
7/6/2012 5:11:25 AM • JBL GTO75.4 Car... • Answered on Jul 06, 2012
2000 toyota avalon cd player keeps ejecting cd
It sounds like you have dirt stuck on the lazer head. Best way to clean it to get a good "wet head cleaner CD".You may have to run the cleaner several times to get all of the dirt off. P.S. make sure to buy a good cleaner disc, not the dollar store brand.
3/21/2012 4:01:21 AM • JBL GTO75.4 Car... • Answered on Mar 21, 2012
Silver mounting plastic frame (exterior) broke.
YEAH IF U CAN GET AHOLD OF JBL THEY CAN PROB.SEND YOU ANOTHER JUST LOOK UP THEIR NUMBER ON THE NET..COM
2/28/2010 8:08:44 AM • JBL GTO75.4 Car... • Answered on Feb 28, 2010
2answers
When i turn my head unit up my amp goes to
check your spker wire to see for a short.
12/7/2009 6:09:46 PM • JBL GTO75.4 Car... • Answered on Dec 07, 2009
CAR CD CHANGER - ERROR 3
replace head unit the cost to fix the problem you could but two deck ,use a wiring harness and get the aftermarket mountain kit
6/26/2009 3:40:39 AM • JBL GTO75.4 Car... • Answered on Jun 26, 2009
Jbl gto 75.4 right channel not working
Hi
It's rare that 2 channels will fail simultaneously, are you sending 4 signals to the amp or just 2?
If you are sending just 2, perhaps the problem lies before the amp in the cabling to it, or the output from the headunit. If you are sending 4 signals then there may be a fuse in the amp that drives 2 channels out of the 4. Of course this may be the case should you just be sending 2 signals.
3/28/2009 10:29:45 PM • JBL GTO75.4 Car... • Answered on Mar 28, 2009
Left speaker channel not working
you may have to send it in or back to the company... being that its one side it could be a blown amp or perhaps a bad speaker on that side ..
hooking up two 6x9s and a sub in bridge mode you could have a wiring problem when i bridge an amp i go from positive of one side and negitive on the other to the same positive and negitive on the sub or box
` bridge =========== > SUB
hope this helps
12/26/2008 3:02:40 AM • JBL GTO75.4 Car... • Answered on Dec 26, 2008
3answers
Amp cutting out, intermittent fault
i suggest using a 4 gauge or smaller i had the same problem. i switched from 8 to 4 and no problems!
9/29/2008 1:54:03 PM • JBL GTO75.4 Car... • Answered on Sep 29, 2008
My Jbl mono amp cuts out
It's likely that the amp has blown output transistors. To eliminate other possible problems, read through the following page:
Amp Going into Protection Mode
Let me know if you have any other questions.
9/17/2008 6:13:41 PM • JBL GTO75.4 Car... • Answered on Sep 17, 2008
AMPLIFIER NOT WORKING
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
8/20/2008 3:04:58 AM • JBL GTO75.4 Car... • Answered on Aug 20, 2008
Protect on car amp
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
5/17/2008 11:15:34 PM • JBL GTO75.4 Car... • Answered on May 17, 2008
Red bulb
If the amp has identified a problem within itself, it could be 1 of a million things. Its best to go get it tested. It shouldnt be too hard if the amp has picked it up.
2/14/2008 2:55:49 AM • JBL GTO75.4 Car... • Answered on Feb 14, 2008
Cutting out intermittent problem
If the voltage is dropping to 8v, it sounds like there is a problem with either the B+ line or the ground connection. You should also check the voltage across the battery terminals to see if the voltage is dropping at the source.
The amp may be going into protect mode. Disconnect all speaker wires from the amplifier's terminals. Also disconnect the RCA cables from the amp. Does it still go into protect?
Insert a 20 amp fuse in the B+ line and try to power it up. If the fuse blows with no speakers connected to it, the amp probably has a blown channel.
12/5/2007 10:37:19 PM • JBL GTO75.4 Car... • Answered on Dec 05, 2007
I have an 4000 watt 6 channel lanzer amp goes into protection mode as soon as it powers on
Could be a bad ground i wish u lived around me I run my own audio installation business
6/23/2022 4:40:20 AM • JBL Car Audio &... • Answered on Jun 23, 2022
I have a JBL 6-disc changer2002 Camry. CDs won't eject. Matter fact when CD option is chosen CD player does not even work at all. Any helpful information would be greatly appreciated!
It sounds like you have a disc stuck and it's overriding any commands. I would put the key to acc. Then I would unplug the cd changer from the back of changer and after a min or 2 plug it back in as you hold down on the eject button
12/13/2021 3:59:40 AM • JBL Car Audio &... • Answered on Dec 13, 2021
How do I advance my jbl 3 disc cd player in my 2008 SOlara
Page 168 of the manual onwards.
2008 Toyota Solara Owners Manual and Warranty - Toyota ...
www.toyota.com > owners > resources > solara > 2008
Find everything you need to know about your 2008 Toyota Solara in the owners manual from Toyota Owners. ..
1/31/2021 10:05:50 PM • JBL Car Audio &... • Answered on Jan 31, 2021
JBL GTO75.4 Car Audio Amplifier Logo
23 questions posted
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
 Mikey
Mikey
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JBL Car Audio & Video
Most Popular Question
jbl gto 75 4 right channel not working
  • Car Audio & Video
