20 Most Recent
Honeywell Air Purifier. True HEPA Air Purifier 17007-HD Questions & Answers
Honey well air purifier 17007 fuse blew. how to
The fuse is located inside the control panel. It is soldered to the circuit board, not mounted in a typical fuse holder. You will need a Philips screwdriver to disassemble the unit. You will need a soldering iron & solder to remove the fuse and replace it. You may want to a multi-meter to check the fuse. If the unit just stopped working, it could be a number of other issues than the fuse. The starter capacitor for the motor could be dead or some other issue. You must take precautions against electrical shock. You may need a technician to safely perform some repairs.
What is this burning smell from my Honeywell air purifier
am sorry to disappoint you, once this condition is reached, it means the motor windings have overheated and your motor needs to be replaced, This is the only best thing to do to rectify this situation. This indicates that the insulation covering the wire used to make the winding of the motor has been cooked by the overheating and it is shorting out ,THIS WILL CAUSE THE MOTOR CATCH FIRE.
Please unplug the unit and have the motor replaced or buy a new unit for your safety.
