20 Most Recent JBL LC-S960 Car Speaker Questions & Answers
3answers
Jvc subwoofer will not power up
you can get the value from this link..
http://www.doctronics.co.uk/resistor.htm
5/31/2015 3:08:36 AM • JBL LC-S960 Car... • Answered on May 31, 2015
My stero says secure how do i unlock it
try pushing the reset button on the radio
6/25/2009 11:21:51 PM • JBL LC-S960 Car... • Answered on Jun 25, 2009
Same as before
That is correct.  I would solder if you cant make the connectors.  they should have two diff sized spades on them.(usually)  I would definately get a crimp kit with crimpers and asst connectors to start.  Also make sure your amp has adequate gnd and large enough power wire with an inline fuse right off the source.  I can make a diagram for that too if you need.
9/23/2008 3:56:12 PM • JBL LC-S960 Car... • Answered on Sep 23, 2008
Speaker installment
I would run a 250-500 watt 2 channel high input capable amp.  run the original wires to the orginal speakers and jump off the original wires to the amp to push the secondary 6X9's you have.  So my understanding is.  you want the 4 original speakers and subs and add 2 additional speakers making 6 speakers not uncluding subs..
Head units care barely push 4 decent normal size speaker.  Usually they are 30-55watt per channel.  If you have 2 non sub speakers that are 250 watt max.. that's 500 total but don't push the amp all the way...start with it at 1/4 and listen to your stereo at a higher than nominal volume slowly turning up the amp.
James Mac
9/9/2008 10:02:33 PM • JBL LC-S960 Car... • Answered on Sep 09, 2008
Wiring on back of head unit
You don't need to change the cables from the head unit on.  Just strip of the end of the wires where the old speakers are and crimp on the proper connectors to connect them.  Alternatively you can just solder the wires directly to the speakers.  I always **** splice at least 6" of wires onto the end so you have more wire to work.  The only reason you would change the wires would be because you are putting more than 200 watts per channel.  You didn't speak of an amp so no worries.
James Mac
9/9/2008 8:37:35 PM • JBL LC-S960 Car... • Answered on Sep 09, 2008
6x9s in a clio
forget it...
buy some speaker cable & run them from the head unit to the boot.
from the back of the stereo connect as follows:
Rear Left
green + to Big Spade on speaker
green/black - to Small Spade on speaker
Rear Right
purple + to Big Spade on speaker
purple/black - to Small Spade on speaker
12/17/2007 7:09:36 PM • JBL LC-S960 Car... • Answered on Dec 17, 2007
I have an 4000 watt 6 channel lanzer amp goes into protection mode as soon as it powers on
Could be a bad ground i wish u lived around me I run my own audio installation business
6/23/2022 4:40:20 AM • JBL Car Audio &... • Answered on Jun 23, 2022
I have a JBL 6-disc changer2002 Camry. CDs won't eject. Matter fact when CD option is chosen CD player does not even work at all. Any helpful information would be greatly appreciated!
It sounds like you have a disc stuck and it's overriding any commands. I would put the key to acc. Then I would unplug the cd changer from the back of changer and after a min or 2 plug it back in as you hold down on the eject button
12/13/2021 3:59:40 AM • JBL Car Audio &... • Answered on Dec 13, 2021
How do I advance my jbl 3 disc cd player in my 2008 SOlara
Page 168 of the manual onwards.
2008 Toyota Solara Owners Manual and Warranty - Toyota ...
www.toyota.com > owners > resources > solara > 2008
Find everything you need to know about your 2008 Toyota Solara in the owners manual from Toyota Owners. ..
1/31/2021 10:05:50 PM • JBL Car Audio &... • Answered on Jan 31, 2021
Mh JBL MR-5 on my boat does not work anymore. Where to replace or how to fix?
No user serviceable parts! If not working just replace!
5/14/2020 3:49:38 PM • JBL Car Audio &... • Answered on May 14, 2020
Jbl a3001 goes into protect mode when bass hits. Wrkd then just stopped. Amazon replaced the amp with a new one, new wire, loc, rca, grnd locatn. No dice. Ideas?
Bad or shorted voice coil on sub maybe. If you have two subs try them one at a time to see if it goes into protect mode. Whatever sub does it is bad.
10/4/2016 3:17:03 PM • JBL Car Audio &... • Answered on Oct 04, 2016
JBL LC-S960 Car Speaker Logo
7 questions posted
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
 Mikey
Mikey
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JBL Car Audio & Video
Most Popular Question
jvc subwoofer will not power up
  • Car Audio & Video
