20 Most Recent
Pride Mobility Jet 3 Ultra Power Chair - Used Electric Wheelchairs Questions & Answers
Lights show code 8. how do we fix it?
hi, sadly this can be a problem fault...
8 A controller system fault is indicated. Make sure that all connections are secure and the batteries are fully charged
I suggest you get it tested to make sure you eliminate any wiring connections etc...
Also I can test and repair those if you based near the UK..
Regards
Rob
Please give feedback...
It does not move but battery is not dead
Here is the manual for your chair.http://www.pridemobility.com/pdf/Owners_Manuals/INTL_Jazzy/Australia/AU_Jet_3_Ultra_om.pdfOn page 33 are the table of fault codes your chair uses it displays these codes by flashing the battery condition meter lamp. Flash-flash-flash----flash-flash-flash----flash-flash-flash, which is a code three service failure. Normally when you get a service code failure its a good bet your controller going to cut off your motors. Get me the code and i will tell what i know about that code.
How often should I visit my dentist?
Most adult and children visit the dentist for regular
checkups and cleanings every six months. People at greater risk should have
checkups more often.
Charger not working plug in light stays green, but battery is not charged
I have got 3 different chargers for my scooter. It's a Tifgalop T108. The charger light would stay green on the new chargers. My old one was the only one that was charging it. While I was replacing the charging ports, I came to find out that the negative wire is in a different location on the new ports. The negative wire was on number 3 on the old ones and is in number 2 on the new ones. After changing the ports all my new chargers work fine now.
