20 Most Recent
Soleus Mini Split 12000 BTU A/C Air Conditioner Questions & Answers
Replacing squirrel cage blower
You have to take blower out by removing the 2 screws that is holding it ,then you loose the motor shaft from wheel by using a Allen key .Once motor shaft is loose you then loosen motor frame from housing and slide motor out .Might have to spray it with wd 40 .
On the housing should be some screws along the side so you loosen those and house ing would open up so you can get wheel out.
To install you reverse the process.
Please note the direction of the old wheel because if install backwards will not work right
Need Replacement filters for Soleus R150
If you need replacement filters for your Soleus R150 air purifier, you can try the following steps:
- Check the user manual: The user manual for your Soleus R150 air purifier should provide information on which type of replacement filters are compatible with your device. Check the manual to find out which filters you need to purchase.
- Contact the manufacturer: Reach out to the manufacturer of the air purifier to inquire about replacement filters. They may be able to provide you with the filters you need or direct you to a retailer that carries them.
- Check online retailers: Many online retailers sell replacement filters for air purifiers, including Amazon, Walmart, and Best Buy. Check these retailers to see if they carry the filters you need.
- Visit a local retailer: You may be able to find replacement filters for your Soleus R150 air purifier at a local home goods store or home improvement store. Check these retailers to see if they carry the filters you need.
When purchasing replacement filters for your air purifier, be sure to check that they are compatible with your specific model of air purifier. It is also important to follow the manufacturer's instructions for replacing the filters to ensure that they are installed correctly and functioning properly.
E4 error on my soleus air conditioner model lx 1400
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it
