20 Most Recent
Soleus KFR-18 Air Conditioner Questions & Answers
Soleus gb-pac-08e4 h8
The unit is NOT pulling water from the air to cause this error, yes they pull moisture out of the air and over TIME fill with water. The problem is that the unit shows the H8 error even when empty. Worked for 2 months and now just keeps popping the H8 code, EVEN THOUGH IT IS EMPTY. Unfortunately sometime you find out after buying a product that it is not quality, that is the case with Soleusair. Bad company, Bad product.
This is Soleus KFR 18,
If you take a close up photo shot with a digital camera I can help you with the control. You have a failed sensor that does not provide the necessary signal that the fan is running and doing it's thing. I need to see the control circuit.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Air conditioner
Go to any BOC Gases outlet and view their range of aircon fans. Depending on model $100 to $200. Fans are not an expensive item.
Allow an hour or two of labour (in case there are problems)
Need Replacement filters for Soleus R150
If you need replacement filters for your Soleus R150 air purifier, you can try the following steps:
- Check the user manual: The user manual for your Soleus R150 air purifier should provide information on which type of replacement filters are compatible with your device. Check the manual to find out which filters you need to purchase.
- Contact the manufacturer: Reach out to the manufacturer of the air purifier to inquire about replacement filters. They may be able to provide you with the filters you need or direct you to a retailer that carries them.
- Check online retailers: Many online retailers sell replacement filters for air purifiers, including Amazon, Walmart, and Best Buy. Check these retailers to see if they carry the filters you need.
- Visit a local retailer: You may be able to find replacement filters for your Soleus R150 air purifier at a local home goods store or home improvement store. Check these retailers to see if they carry the filters you need.
When purchasing replacement filters for your air purifier, be sure to check that they are compatible with your specific model of air purifier. It is also important to follow the manufacturer's instructions for replacing the filters to ensure that they are installed correctly and functioning properly.
E4 error on my soleus air conditioner model lx 1400
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it
