20 Most Recent Hobart FP41 16 Cups Food Processor Questions & Answers
have you tried to replace the contactor and see if that helps at all? If there is another issue like a bad switch contact then you can still replace that becuase some of those parts are universal
Hobart FP41 16... • Answered on Feb 28, 2011
It is a thermistor and the value should be approximately 100k ohms at room temp.
You can substitute a pair of 100k ohm resistors to allow operation but to actually get the protector board to function as designed you will need the ~100k ohm thermistor with the correct temp / resistance curve bonded into the stator.
An option would be to use a standard motor starter for the protection although the wiring gets a bit tricky with the relays, aux switches and the reversing contactor.
Another option would be to imbed / affix a klixon type overload into the windings and wire this in series with your 100k ohm resistor.
This will still allow the board to indirectly protect the motor.
Hobart Food... • Answered on Mar 22, 2010
I have uploaded it here:
http://rapidshare.com/files/362384070/F13628.pdf
Please rate my answer if I helped.
Thanks
Hobart Food... • Answered on Mar 12, 2010
Hi, I just received an older 1612 Hobart, and fixed the same problem.
First i disassembled the linkage from the bottom, then i used a propane torch to heat the rods and the aluminum castings (carefully, bring the temp till it is hot to the touch) Hammering doesnt work well so i made a piece of pine appx 1x1" with a notch to use as a pry stick. put a thin piece of plywood against the casting so you dont crack the housing, as it is thin alum.
Worked for me, take your time
Hobart Food... • Answered on Jan 03, 2010
PHIL SMITH HOW DO YOU CHANGE THE BLADE ON HOBART SLICER 1712??
Hobart Food... • Answered on Nov 03, 2009
check the link below for answers https://www.google.com/search?q=Food+Saver+vs+0150&oq=Food+Saver+vs+0150&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Food Processors • Answered on Apr 16, 2021
Question is what I wonder .............
Food Processors • Answered on Apr 09, 2021
HOME MADE NOT DONE CORRECTLY
Food Processors • Answered on Mar 27, 2021
Hobart FP41 16 Cups Food Processor Logo
Popular Tags
1 questions posted
Top Hobart Food Processors Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Hobart Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Hobart Food Processors
Most Popular Question
when turn
  • Food Processors
