20 Most Recent Bulova Diamond 98W06 Watch for Women Questions & Answers
I would expect the battery to last more like 3 years than three weeks.
Did you replace the battery yourself? If so, are you sure that it's the correct one correctly fitted? Did you use a quality make of battery?
I've known people to use metal tweezers to fit batteries - the risk of shorting the battery is very high with the result that battery life is seriously reduced.
Look at it this way - the watch cost you over 300 bucks, so it's a decent quality watch. Take it to a professional to have a battery fitted - it's not worth the risk doing it yourself if you're not completely sure what you are doing, and if the battery they fit fails then you can just take it back to them to sort out. Having a battery fitted for you should not cost a lot of money - but if you have somehow damaged the watch by trying to do it yourself then it will have been a very expensive way to save a little money....
Bulova Diamond... | Answered on Oct 17, 2017
pop the back off and look, battery should have a number on it.
Bulova Diamond... | Answered on Sep 07, 2014
NEED MORE INFO. From that serial number, it might be one of the old tuning fork movement watches. If the date code is from M0 (1960) through N6 (1977) it likely is. If so, it has a collector's value. In any case, the exact model, type of movement, and year would be needed to come up with a value. The serial number is just not enough.
Bulova Diamond... | Answered on Aug 06, 2014
Under watches? No not here...
Bulova Diamond... | Answered on Jul 25, 2014
You're trying to open the watch, not your fingers. If it is stubborn and you are worried about a possible mishap, take it to Wal-Mart instead.
Bulova Diamond... | Answered on Jan 23, 2013
https://www.quora.com/How-do-I-know-which-battery-I-need-to-fix-my-bulova-watch
I have changed batteries on watches before but none were bulova. I opened the back which you have to do to change battery find what battery you need and order online. I have been able to find at stores year ago but most watches now days people don't change batteries they buy new watches. It is a little harder to find batteries in stores.
When you find the type battery google to get the place to buy it.
https://www.energizer.com/specialty-battery-finder/bulova-watch-battery-replacement
Bulova Watches | Answered 3 days ago
take it to MACYs and say , can you pop in a new battery.
or any watch repair shop, can.
this is very old cheap watch and manuals are not easy to find.
Bulova Watches | Answered on Mar 01, 2020
we dont value anything here
Bulova Watches | Answered on Aug 20, 2019
https://www.youtube.com/watch?v=UR9yVjrFyiE
This is merely a video on how to reset the second hand on your Marine Star.
But perhaps it has some information that will be helpful to you.
Bulova Watches | Answered on May 30, 2019
Google (Bulova)(97C106)(manual) without parens for instructions.
Bulova Watches | Answered on Dec 25, 2018
I just got a M.Z. Berger AW206 366 so the setup should be identical.
The watch has four buttons total. I'll name then by their positions. Top Left (TL), Top Right (TR), Bottom Left (BL), and Bottom Right (BR).
(BL) is your mode switch. Press it once at a time to toggle between modes, (Time, Chronograph, and Alarm). From the Time mode press (BL) three times. This will put you back in time mode with the seconds flashing. Press (TR) to toggle seconds back to '00'. Press (BR) to toggle to the next setting point, and (TR) to advance it. Just keep pressing (BR) until all the settings points are the way you want them. Note: In time setting mode it only advances the setting forward when you press (TR). So when using it to change hours display for 12/24 hour display or daylight savings time you just have to keep advancing the hour until it shows up correct. There is no DST or 12/24 display toggle on this watch. You just have to change the hours display manually. To exit time setting just press (BL) once.
Bulova Watches | Answered on Nov 12, 2018
Bulova Diamond 98W06 Watch for Women Logo
Popular Tags
0 questions posted
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
View Most Popular
Diamond Bulova
  • Diamond Bulova
Most Popular Question
remove back face replace battery
  • Watches
