20 Most Recent Swiss Legend Chronograph Stainless Steel Case Black Rubber Band 40021 11 Watch for Men Questions & Answers
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Swiss Legend... | Answered on Nov 09, 2013
This movement wasn't meant to be repaired, so replacement is your only option. These pop up new on eBay from time to time for around $30 shipped. Make sure you get one with the date in the correct orientation/position (e.g. date at 3 o'clock or date at 4 o'clock). Best to enlist the services of a watchmaker if you haven't removed and replaced hands on a watch before (particularly a chronograph).
Swiss Legend... | Answered on Aug 11, 2009
1 Nonstandard Battery required
Swiss Legend... | Answered on Apr 23, 2019
Take your Swiss Legend watch to a jeweler for identification of battery type and possible installation of a new one.
Swiss Legend... | Answered on Mar 28, 2018
The links are removed by a variety of methods. Look at the side of the link, is there a small pin? if so there will be an arrow on the back of the link. this is the direction to push the pin out. there also may be a flat pin in the end on the back of the link you will see a little round hole covering half the pin this will need a jeweller to remove.
Swiss Legend... | Answered on Jan 09, 2018
Common solution, locally.... :)
Swiss Legend... | Answered on Nov 04, 2017
Hi Leigh.
The battery supplies voltage to a precise timing circuit to generate brief pulses of low voltage electricity to a magnetic coil which swings a weighted cam (wheel) to keep everything in motion.
This cam or some other mechanical part may have become dislodged or misaligned, causing drag.
In a nutshell, a watchmaker will need to inspect it for wear.
Could be a jewel-bearing has fallen out.
Does this help?
Regards,
Clive.
SORRY but FIXYA can not tell as we can not see the battery numbers
Swiss Legend... | Answered on Sep 13, 2017
Sorry...
New or not SWISS use the second hand as an early indicator of the battery state.
My memory is that it starts by skipping seconds...
Then the second hand stops...
Then the watch...
ELSE
The movement is bad.
If it is INDEED NEW... Take it back & get
yourself a fresh one.
Carnac the Magnificent
Swiss Legend... | Answered on Mar 26, 2017
Swiss Legend Chronograph Stainless Steel Case Black Rubber Band 40021 11 Watch for Men Logo
7 questions posted
Top Swiss Legend Watches Experts
Janelle Schoonover
Janelle Schoonover
Clive
Clive
Tom Chichester
Are you a Swiss Legend Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Swiss Legend Watches
Most Popular Question
swiss legend chronograph stainless steel
  • Watches
