20 Most Recent
Stoves Premier 600GRa Gas Single Oven Questions & Answers
Oven cuts itout when it gets hot but the power
as it is when your oven runs normally it usually does an on and off type of running in which the ignitor lights the flame from the gas which stays on until the oven tempreture sensor tells the control board that the oven is hot enough at which time it shuts off the gas until the oven starts to go maybe 10-15 degrees below the tempreture at which time it would let the gas go through the line again and turn on the ignitor try checking your ignitor usually if you stick an amp meter on them should be drawing 3.3 amps plz remember to shut off the gas from the gas shut of valve in the rear of the machine before measureing for the amps hope this helps
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Stoves 900GTFThermal Switch
If you have paid for warranty insurance, read the small print. I think you will find, if it is not repairable, they must replace it with an equal or better unit.
10/16/2022 2:54:47 PM •
Stoves Ovens
Answered
on Oct 16, 2022
