20 Most Recent Stoves Premier 720EMa Electric Double Oven Questions & Answers
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Stoves Premier... | Answered on Aug 23, 2015
how do i change grill element in top oven
Stoves Premier... | Answered on Nov 20, 2012
Probably went bad a lot of exhaust dirt gets in there. Make sure power is off take it out and replace it ,you can find one at your local Grainger if not they can match it up.
Stoves Premier... | Answered on Apr 08, 2011
The fan is squeaking/rattling in our Stoves q720em double oven. Any easy / cheap solution please!?
Stoves Premier... | Answered on Feb 13, 2011
I have a 720ef and the top oven is not that good. The wattage rating is low, from memory about 750 watts and it takes a month of Sundays to warm up. I bought an oven thermometer from Lakeland a little while ago and when the top oven is turned on the Lakeland thermometer is showing that the oven thermomostat is running the oven at 20 degrees below what it is set to. If the thermostat neon is clicking off and on, then the thermostat/oven is working, albeit not as we expect.
Stoves Premier... | Answered on Oct 30, 2010
Hi.
Premier is a small company, and does not make available their manuals for online download.
The manual can be ordered calling Premier Ranges at the toll free number : 800-858-5844.
Some information is also available on their FAQ page.
Regards.
Stoves Premier... | Answered on Mar 02, 2010
Like most ovens you press the 2nd and 3rd buttons simultaneously (cook duration & finish time). While doing so, use + or - to set the time.
Stoves Premier... | Answered on Oct 27, 2009
It sounds like you have no power to the the grill. Check the grill circuit with a tester until you identify where you have power to and then check for loose connections or broken wires from there on.
Stoves Premier... | Answered on Nov 29, 2008
Request the diagram directly from Samet.
Stoves Ovens | Answered on Jun 22, 2020
try Google make model and manual
Stoves Ovens | Answered on Dec 05, 2019
Stoves Premier 720EMa Electric Double Oven Logo
16 questions posted
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Stoves Oven Expert? Answer questions, earn points and help others
View Most Popular
Stoves Ovens
  • Stoves Ovens
Most Popular Question
dual grill not work
  • Ovens
