20 Most Recent Canon ZR-950 Mini DV Camcorder Questions & Answers
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Canon ZR-950... | Answered on Jul 21, 2011
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Canon ZR-950... | Answered on Apr 07, 2011
Try this:
1.Change the position of the protect switch on the MiniDV cassette tape
2.Rewind the tape on the camcorder or insert a new tape
Canon ZR-950... | Answered on Mar 19, 2011
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Canon ZR-950... | Answered on Nov 04, 2010
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Canon ZR-950... | Answered on Sep 18, 2010
If you are getting a blue screen while trying to play back a tape that you know has a recording on it then its gonna be 1 of 2 things, No.1 your video heads have gotten dirty and you need to get a cleaning tape to run through the tape path to clean the unit, or No2 if your cleaning it doesnt help then you are going to need to have the video heads replaced. Usually once the heads are replaced they check the alignments for you as well and do a proper cleaning. I hope this helps
Canon ZR-950... | Answered on Sep 16, 2010
You could try slaving the camera out to an external screen if you have the cables, you should find a RCA output socket on the camera marked video out (commonly known as a phono)normally yellow also a couple of audio out sockets one red and one white.
If you plug the yellow one into an external monitor you will see if it's the camera LCD screen that faulty.
Also check the iris is not turned down when playing back or recording this can happen if the camera is set to manual.
Set the camera to automatic and try again.
It sounds to me that the iris is closed, if the head drum is spinning you should get something even if it's random signal noise denoting clogged heads anyway the camera would flash up a clogged head icon so first as check the iris.
Canon ZR-950... | Answered on Sep 13, 2010
Well it can be a bit of a "Mission" Here's what I would do. OK, The BEST way is to get a TV/Video Input card or USB Dongle. And DVR software, usually this comes with the unit. Or use Dscaler, (Link below) the BEST video recording program out there. Anyway, Hook up the Camcorder, to the Video Input on TV/Video Input device .Open up the recording software, and then "Play" the "Tape" then, start the "DVR" Recording. Save the streamed Video as a MPEG4 or whatever you wish to save in. Then you have a Digital recording of what was on the tape, safely stored as a "Movie" on your computer. You can then use Movie making software to digitally manipulate the Video's as you wish. You could then simply copy the movie to the Flash card, or copy/paste from the recorded location on PC, to the flash card, via a Flash card reader.
Some camcorders, have a Firewire, Or USB, built into them. IF you wish to use this method, then you would need to download and install "Driver" software First, and than, you can do more or less the same as above, simply selecting THAT Input, as the Video Stream, again, Play the "Tape" and it outputs via the Cable to the PC, and DVR, software. Again, you can do as you wish with the flash drive.
Below, is the canon link for the software you need for your camera. Also download the manual and follow the instructions in there it will help you. Below that is the Dscaler DVR. (Another good one is KMPlayer)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=326&modelid=16172#DownloadDetailAct
www.dscaler.org/
Canon ZR-950... | Answered on Apr 22, 2010
you need Ulead 11 (20 bucks at Ebay) program and a firewire cable. install the program. connect the camera to the computer with the firewire cable turn the camera on and put on play mode. follow the on screen prompt.
Canon ZR-950... | Answered on Apr 12, 2010
Hello :
Check this link here please . You need to select your OS first .
I hope that you'll rate !
good luck .
Canon ZR-950... | Answered on Apr 10, 2010
Canon ZR-950 Mini DV Camcorder Logo
Popular Tags
29 questions posted
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
ZR Canon
  • ZR Canon
Most Popular Question
canon camcorder power quit
  • Video Cameras
