20 Most Recent
Street Glow Streetglow Streetglow H894 Headlight Replacement Bulbs Questions & Answers
Change the headlight on a 2006 Chevy Equinox
The front bumper cover does have to come loose at the top. Remove the retainers along the top of the front bumper cover on top by the radiator and loose the part of the grill that goes over the headlamp. cover with tape to avoid scratching the lens . then remove the 3 bolts for the headlamp. Two at the top and one down at the bottom inboard side. Then pull the headlamp at the outobard bottom to release the retainer and remove the headlamp.
Headlight replacement
should be able to access them from within the engine compart ... you may need to remove the battery if it's on that side.... and don't put your fingers on the bulb... that will shorten it's lifespan
Robert
Please take a moment to rate this solution.. thanks
How do you replace a headlight bulb on a Suzuki Gran Vitara 2006?
Disconnect the electrical coupler behind the headlamp under hood then remove the rubber cover. There's a clip that holds the bulb connector (holder) in place. Desengage the clip and pull the bulb and connector out. The main key is to pay close attention to how the connector was originally positioned to assure proper placement when placed back. Replace the bulb and repeat the process in reverse order.
Headlight bulb replacement
It's easy to change the bulbs. You don't have to remove the bumper.
To start at the left front, jack up the left front of the car, turn the wheel to the right, remove the plastic plugs and two screws holding the plastic fender liner in place (there are two pieces - loosen the front most piece) and pull it down. You will see the back of the headlight housing. Unscrew the caps and install the new bulbs. Reassemble and repeat on the other side.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
