20 Most Recent Street Glow Streetglow Streetglow H885 Headlight Replacement Bulbs Questions & Answers
could be problem relays or light switch
Street Glow... | Answered on Sep 10, 2017
Go to YouTube. There is a how to video on there.
Street Glow... | Answered on Jul 24, 2014
What exactly is the problem? Please specify your problem...
Street Glow... | Answered on Dec 30, 2013
  • Check the headlamp wiring
  • Check if the fuse amp. is proper
  • If there is any shorting in the wires then the bulb will glow but it will become dim
Street Glow... | Answered on Feb 26, 2011
check the fuses on the car
a little more info will help give a more detailed fix
Street Glow... | Answered on May 29, 2010
i had a crossfire with the same problem, I pulled the globe and the headlight just to find that there are individual fuses for left and right, double check your fuses before replacing the globe, good luck
Street Glow... | Answered on Jan 01, 2010
The dimmer swich is suspect, Its mixed in with the turn signal switch wiper switch. sometimes it can be found watching the lights to push in and wiggle the turn signal switch if it comes on low at all doing this the switch is bad. It fails alot everyauto parts store should have it and take the covers off the collum to change it don't forget to check the plug that plugs into the switch for burnt connectors or backed out wires. find the wire that comes hot when you put power right on the low beam wire on the headlight ( lows will be on ) there'll be a wrre that came hot that wasn't with every thing hooked up, Unhook jumper and hook right at switch if it works from the switch the switch is bad. Change and ride saftly at nite. Some models have daytime running lights and the fuses for them are in their own fuse panel and have heir own relay this doesn't happen very often.
Street Glow... | Answered on Aug 11, 2009
Not a short. FIRST check your battery connections. These can get corroded and turning on the headlights breaks the corrosion enough to allow power to the system.
Street Glow... | Answered on Jul 27, 2009
I re-wrote your question and I put you in the right Category :>)
Your unit, only available FROM Japan, and as Larry says many are for the Japanese home market only, and a sold ONLY in Japanese language.
Your unit
https://www.nengun.com/clarion/av-integrated-memory-navigation-nx710-897085
There is help here
Car Electronics Technician: Russell H.
The question about the problem, with a GPS or stereo device in a car, that turns out to have an interface in Japanese is, whether the car it is in was intended for the Japanese market.
Generally, in a car that was intended to be sold in Japan, the language in the included devices is in Japanese and has no capability to switch language, unfortunately. Is it possible that your car is indeed an intended-for-Japanese-market car?
I am looking up the info on changing the language for that model, if it is possible. I will post later with that information, if I can find it.
Try this:
On the main screen, touch the triangle with the gear icon.
Then the first entry should be the System Language (no matter what it looks like in Japanese kanji, it should be at the top of the gear-icon Settings screen.)
Touch the language displayed there (whatever it looks like) and see whether there is any choice that looks like
English
If none of the language choices are in anything but Japanese kanji characters, then you may have to work through each choice, seeing whether it changes the interface to something else than Japanese kanji characters, until you hit upon one that matches what you need... regrettably there may be no other practical way of getting to the objective here.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01psddnS7TgS3hZNjVHYFzT-FDO0A%3A1610557271600&ei=Vyf_X-j7I4Gk5NoPy9aPuAI&q=clarion+nx710+change+language
You can also use a Smartphone and with the Google Translation app, use the Camera feature to translate what you are seeing. Look for Settings - Language
Car Audio &... | Answered 2 days ago
I would assume this is 1000W peak-to-peak, so divide by 2.83 = 350 rms, or 88W rms per channel.
See link for bridging information:
Car Audio &... | Answered on Jan 10, 2021
Need to know which wire gose where
Car Audio &... | Answered on Jan 04, 2021
Pull straight out on knob.
Car Audio &... | Answered on Dec 30, 2020
Contact RDP to request the wiring diagrams (not schematics).
Car Audio &... | Answered on Dec 27, 2020
Street Glow Streetglow Streetglow H885 Headlight Replacement Bulbs Logo
25 questions posted
Top Street Glow Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Street Glow Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Street Glow Car Audio & Video
Most Popular Question
1998 isuzu rodeo head lights
  • Car Audio & Video
