20 Most Recent
Soundstorm S7EQ 7-Band Car Equalizer Questions & Answers
I ONLY GET POWER FROM
Make sure you are using the blue/white instead of the blue wire to turn your eq on. blue is power antenna remote and turns off when leaving tuner mode.
Modelo sd745t radio para coche tengo problemas que el panel fron
Es posible que alguno de los switches este defectuoso y se a de haber quedado oprimido y eso causa que se bloquen todos las funciones.Por lo regular,cuando un switch esta defectoso no se siente el click al oprimirlo.
Espero que esta informacion te ayude en algo.
Gracias y suerte
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
