20 Most Recent Stoves 600SiDOm Gas Kitchen Range Questions & Answers
Look at the back or just inside the oven for two screws that allow the top to tilt up.
Stoves 600SiDOm... | Answered on Oct 01, 2015
if you have electronic igniters you may get a wiff of gas at start up.
make sure your igniters are set properly so the burner lites right away and does not click click click for awhile before starting.
Stoves 600SiDOm... | Answered on Jun 21, 2015
Check the main oven burner and look for a small thin bar that goes across the burner on the left or right hand side, push it down and across into its seating. its part of a sensing device for the gas flow
Stoves 600SiDOm... | Answered on Mar 29, 2015
it is in the gas line to your burner, you need to call a technician. do not play with it, as you can create a gas bubble and burn yourself.
Stoves 600SiDOm... | Answered on Mar 01, 2015
The door seal is about 35 the element around 75.00. If you use self cleaning the element burns as high as possible. Therefore the element could have been damaged. I believe 5 to 7 years is the norm. Have a good day.
Stoves 600SiDOm... | Answered on Sep 05, 2014
You need a gas connection .then flex tube channel locks or a pipe wrench and some Teflon tape. Connection should have shut off valve.should be shut off. Put Teflon tape on threads then connect the connectors. Open valve.check your work twice listen and use your nose for a foul smell.
Stoves 600SiDOm... | Answered on Jul 15, 2014
lift the push button up a bit if dont work u need to replace the push button. bsc appliances uk...07779933829 postal service too.
Stoves 600SiDOm... | Answered on Jun 30, 2014
Hinges are available for most oven doors. Be aware they can be difficult to fit sometimes. Find the model number & serial number then contact the manufacturer.
Stoves 600SiDOm... | Answered on May 08, 2014
Contact manufacturer for wiring diagram.
Usually the problem is the gas (safety) valve. It may need replacing at $220 Canadian or so for parts. Of course in the USA everything is half as expensive as here. Sometimes it is working fine but requires 2 or 3 minutes to cycle through before it works.
Stoves 600SiDOm... | Answered on Oct 16, 2013
Kathy it all depends on where it is can you post a photo, some gas cook-tops are impossible to clean for the perfectionist.. I always mumble about mine... I cannot find a correct image of your appliance
Stoves 600SiDOm... | Answered on Oct 13, 2013
unless it is specific any electrical wholesaler will have units to fit your stove. Just take a sample.
Stoves 600SiDOm... | Answered on Jun 22, 2013
Stoves 600SiDOm Gas Kitchen Range Logo
107 questions posted
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
Ned Halaweh
Ned Halaweh
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Stoves Kitchen Ranges
Most Popular Question
stop igniter from clicking gas
  • Kitchen Ranges
