20 Most Recent
Corel AE CorelDRAW Graphics Suite 12 for PC Questions & Answers
When I try to install corel12 I get a message error applying transforms.
If you are well versed with editing the registry, that will be the second thing you might have to do. First try running the uninstall for the software, then reboot the computer before trying again. if that does not work, DO NOT edit the registry if you don't know what you are doing, you can cause more damage than you already have.
One last thing you can try is to create a new profile and make the profile have admin privileges then log into that profile and install the software there. The new profile might work. I spent 25 years servicing computers for a big company, and i will I could put 10 years of experience in your head with a simple message, but sadly that can't happen. Good luck , Joe
12/23/2018 7:15:51 PM •
Corel AE...
Answered
on Dec 23, 2018
Corel draw is not open plz help me
coreldraw x5 (Portable Vertion) not opend.Error :The application was unable to load a required component :CrlUtl.dll. Please contact the publisher of this application for more information.
8/29/2018 5:45:04 AM •
Corel AE...
Answered
on Aug 29, 2018
Out Of memory error
In short you need a lot of memory for doing such things in Corel and many other applications. Operating systems are not what they used to be and every driver and every option enabled uses more and more of the precious RAM capacity so the only option is to get more RAM into your system. You should try to get 4Gb and this operation will go ahead with no problems.
1/4/2013 9:48:12 AM •
Corel AE...
Answered
on Jan 04, 2013
Corel draw files do not open
Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
6/21/2012 3:00:08 PM •
Corel AE...
Answered
on Jun 21, 2012
How to empty your C:/temp folder.
Use windows explorer to navigate to the c:/temp folder. Highlight the folder by left clicking on it. Then click on the edit tab in the upper left of windows explorer and choose "Select all". Now hit the Shift key and hold while hitting the delete key. Select "Yes" and poof they're gone.If you want to rid yourself of more temp files in different directories with ease, then get a FREE app called CCleaner from here and give it a try:Link:
http://www.piriform.com/ccleaner/download/standard
5/21/2012 12:04:00 PM •
Corel AE...
Answered
on May 21, 2012
Hi my problem is: File
Increase the page file size to double which can be done from computer properties(system) -- advanced tab, open perfomance settings -- advanced and in virtual memory assign a higher value for each partition. Restart computer for them to take effect
5/3/2011 12:03:49 PM •
Corel AE...
Answered
on May 03, 2011
I recently printed # 10 envelopes and now when I
in your settings there is an option to restore to default or "default settings. theis should restore the settings back to normal. if there is a checkbox to make this size default...do not check it next time or remove the checmark next time. hope this helps
2/6/2011 4:32:16 PM •
Corel AE...
Answered
on Feb 06, 2011
