20 Most Recent
Acard Technology ARS-2033S DVD-R Burner Questions & Answers
I have a ARS-2030T/2033/2033P/2033S/2039
Hi Linda,
Welcome to Fixya. Target Drive Not Ready - This message means that the burning drives are not recognizing the blank media. There are a few things to try and remedy this though the unit may need repaired.
First, try using all of the bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.
2nd, try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.
If you have questions please let me know. Thanks for using Fixya.
On boot the message "copier f/w fail please update fw" appears.
I have flashed just 1 DVD drive, years ago. It was easy when you knew the trick. The download site should have told you how. You must get the firmware to read and remember the update flash.
That said, I stopped flashing firmware long ago. If it ain't broke, don't fix it. I was given this info and I pass it on. Lots of folks update, upgrade and flash their way to real trouble.
Cannot access cd in sourcw drive
Can you access the CD when it is inserted into a different computer?
Can you access a different CD when it is inserted into your computer?
