20 Most Recent
JBL SCS125A System Questions & Answers
Subwoofer "thumping" w. no audio feed
You need to check your ground connection. If there is a bad ground there will be feedback to the amp and it will just sit there and loop back with the Thump, Thump, Thump sound. I had to wire my amp's ground all the way back to the negative battery terminal. It was a pain but I have never had a problem since :)
4 out of my 5
Before you blame the speaker one simple test needs to be made, if you have not done so already.
If one remaning speaker has full volume output, swap one of the 'defective" speakers to that same channel the "good" speaker was attached to, and see if the output drops.
Thumping when not hooked up
First thing to check are signal cables but broken fuse telling me that problem is 99% in sub power supply unit or the amp.If you have a voltmeter and if you KNOW how to do it dissasembly it and check DC voltage on a speaker conntacts.If there is any DC present your amp is worn out.But this can be VERY DANGER because 220/110V is there so if you are not 100%sure that you can do it DON'T!!!
I need JBL Eon One Compact power supply circuit diagram
The manual is here. There is no service information available anywhere.
https://adn.harmanpro.com/site_elements/resources/19929_1572546665/JBL_EON_ONE_Compact_User_Guide_original.pdf
Claim in their 3 year warranty if there is a fault with it.
Mailing Address: JBL Professional 8500 Balboa Blvd. Northridge, CA 91329 Shipping Address: JBL Professional 8500 Balboa Blvd., Dock 15 Northridge, CA 91329 (Do not return product to this address without first obtaining prior authorization from JBL)
Customer Service: Monday through Friday 8:00am - 5:00pm Pacific Coast Time in the U.S.A. (800) 8JBLPRO (800.852.5776)
www.jblproservice.com
On The World Wide Web:
www.jblpro.com Professional Contacts, Outside the USA: Contact the JBL Professional Distributor in your area. A complete list of JBL Professional international distributors is provided at our U.S.A. website:
www.jblpro.com
Product Registration: Register your product online at
www.jblpro.com
2/16/2022 2:09:12 PM •
JBL Audio...
Answered
on Feb 16, 2022
