20 Most Recent La Crosse Lacrosse WT-5120U-BP Projection Alarm Clock Questions & Answers
I've had this clock for a year now. The projection light will no ...
www.amazon.com/clock-projection-light.../1?_... Amazon.com, Inc.Sep 13, 2013 - The projection light will no longer stay permanently on - it used to. ... if it during the day you can't see the projection because of ambient light. Questions And Answers: does the projection light stay on 24 ...
Jan 7, 2014
Amazon.com: Questions and Answers: Oregon Scientific RM313PNA ...
Jul 19, 2013
More results from www.amazon.com
La Crosse... | Answered on Oct 19, 2015
Instructions...
you have to release the Mode/Min button after 3 seconds.
http://www.klockit.com/pdfs/87214.pdf
"TIME ZONE SETTING
1. Hold down the "MODE/MIN" button for 3 seconds, the time will flash in the Time LCD.
2. Press and release the "SNOOZE" button to advance to the time zone selection.
3. In the indoor temperature/humidity section of the LCD the time zone will flash."
La Crosse... | Answered on Jan 19, 2011
I found my manual so it is up and running again. Thanks
La Crosse... | Answered on Oct 11, 2009
Press and release the ALM key in the normal mode display.
If you need a manual, you may download one here.
La Crosse Audio... | Answered on Mar 03, 2012
Did you try adjusting the time manually? Did you adjust the time zone/ city setting on them as well? If you need further assistance give me the exact model and i can assist you further.
Thank you,
Lee
La Crosse Audio... | Answered on Mar 18, 2010
After connecting one, turn on the other. Then while both are powered on? Press and hold the button on both earbuds until they connect to one another.
Audio Players &... | Answered 6 hours ago
Check the connections you have made properly or not, after that if there is no sound coming then maybe your subwoofer has defected and also check the subwoofer its wire are connected to the coil or not.
Audio Players &... | Answered Yesterday
here
https://www.allpartsinc.com/circuit-board-avr-automatic-voltage-0065649.html
NOTE
This 0065649 AVR Automatic Voltage Regulator has replaced the older style AVR's used by Coleman and Pramac.
The 0065649 AVR and the S0062490 Wire Harness should be ordered together if you are replacing any of the old style AVR's including the following part numbers:
0062479 AVR Automatic Voltage Regulator
0052627 AVR Automatic Voltage Regulator
0052795 AVR Automatic Voltage Regulator
or here
https://www.arkansas-ope.com/CANADA_COLEMAN_GEN_PARTS.html
La Crosse Lacrosse WT-5120U-BP Projection Alarm Clock Logo
10 questions posted
Top La Crosse Audio Players & Recorders Experts
Tom Chichester
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a La Crosse Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • La Crosse Audio Players & Recorders
Most Popular Question
only shows et time
  • Audio Players & Recorders
