20 Most Recent
Genius SP-K10 Computer Speakers Questions & Answers
Twin Genius speakers model SP-K10 now carrying
Could be interference from another electrical device or a loose connection. Or you forgot that you were watching Saving Private Ryan.
Turn off the movie, and then try moving them away from anything electrical; TV, monitor, PC mainly. Cordless phones can do it as well.
No voice
if you mean your microphone is not working
control panel sounds and audio devices select advanced there might be a tick in the mute box untick or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
MY PC SPEAKERS HAVE STOPPED WORKING
I cant seem to find any support for it either. But just check your jacks to make sure all is plugged in.
Next, go to:
Control Panel > Sound
Go to the Playback Tab and right-click on the jack that you are using the speakers for. Choose Set as Default and then check the volume levels. You can try restarting and hopefully it will work.
If not, try updating Windows from: Programs > Windows Update. Then restart your computer again. Beyond that it could be many things.
My speakers are on but
Your speakers might be on, but the audio device is the sound card (seperated or on motherboard). Please clarify me the brand/model for your computer in order to give you further details.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
No sound
format ur c drive and reinstall ur audio drive
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
