20 Most Recent Westinghouse DPF-0802 Digital Picture Frame, Digital Photo Viewer Questions & Answers
The digital frame only has 8mb of Internal memory, And if you’re using a high-resolution camera that means you’re only going to get a few pictures loaded into the internal memory. You would be a lot better off playing your pictures directly from the CompactFlash card. Once you place a flash card into the frame it automatically should go into a slide presentation mode and then you should do is hit play.As far as loading it from your computer you need to get a mini USB cord and connect that to the computer and the frame. Once the computer recognizes the frame you can do the transfer.
Westinghouse... | Answered on Oct 31, 2017
Try removing the offending image - the format may not be compatible with the frame
Westinghouse... | Answered on Aug 27, 2017
Go to any place that sell cables ( Best Buy, Staples etc) and ask for a
USB to Mini USB cable ... about $10
Westinghouse... | Answered on Aug 05, 2011
Some frames are not able to use an SDHC card. You might double check the requirements from the manufacturer... or even easier, try a card that is just a plain-jane sd card.
Hope this helps!
Westinghouse... | Answered on Feb 23, 2011
How do I load up the pictures?
Westinghouse... | Answered on Oct 19, 2010
The manual is available HERE. Select Digital Photo Frames and then select your model.
Westinghouse... | Answered on Sep 18, 2010
Go to start menu, open up my computer, you will see your flash drive. Leave this window open.
Then go and open up the file with your pictures on it. If you want to add all pictures, click the very first one so it is highlighted, then hold shift key down, scroll down to the very last picture and click on it, then let go of shift key and all pictures will be highlighted, then click and hold mouse button on any pic, drag the entire thing of pictures back over to the flash drive folder. Let go of the mouse button and all pictures will be added to your flash drive. You can also do this one picture at a time if you wish.
Westinghouse... | Answered on May 20, 2010
You need to download them onto the frame
Westinghouse... | Answered on Jan 21, 2010
Here you go. click on the link below for the manual
http://www.westinghousedigital.com/pdf/208_User_Manual.pdf
Good Luck and Please Rate FixYa!
Westinghouse... | Answered on Jan 20, 2009
Westinghouse DPF-0802 Digital Picture Frame, Digital Photo Viewer Logo
36 questions posted
Top Westinghouse Photography Experts
Marvin
Marvin
Tony Parsons
Tony Parsons
Are you a Westinghouse Photography Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Photography
Most Popular Question
39 t find cord
  • Photography
