20 Most Recent Sigma EF-530 DG ST for Pentax TTL Flash Questions & Answers
Sigma EF-530 DG ST - not working, on test or camera all 6 LED lights displaying. Any thoughts?
I don’t usually play with flash that isn’t built in- I prefer natural light, but...if this were me I would: A) take very fine sandpaper and very lightly go one time over all contacts for the flash and camera. B) I would also see if my button batteries in my camera needed changing. As I remember they have something to do with recognizing lenses and flash attachments. C) I would also make sure the batteries in the flash, although changed, were making proper contact with the battery terminals and might also lightly sand those as well since the flash is little used.
1/10/2018 4:48:08 PM • Sigma EF-530 DG... • Answered on Jan 10, 2018
Sigma 70-200mm f2.8 APO EX while on Autofocus mode the focus ring moves slightly when half-pressing. Is this normal? is there anyway to fix this?
It is not normal for the focus ring to move slightly when using autofocus mode on the Sigma 70-200mm f2.8 APO EX lens. This could be caused by a problem with the lens or with the camera body. One thing you can try is to check if the lens mount on the camera is clean and free from debris, as this can cause the lens to move when the camera's autofocus system is trying to adjust the focus. You should also check if your lens firmware is updated to the latest version and make sure your camera firmware is also up to date.
1/12/2023 12:18:13 AM • Sigma Cameras • Answered on Jan 12, 2023
Hello All, I need instructions on how to dissasemble the Sigma 300-800mm f5.6 APO EX DG HSM lens to clean an inner element. Does anyone have a service manual/exploded views/parts diagram please?
You can't do this yourself. It needs to be carried out by professionals and is a 'clean room' with service techs in full dust proof protective wear. Send it to them. https://www.sigma-global.com/en/support/ ..
10/5/2022 11:27:10 PM • Sigma Cameras • Answered on Oct 05, 2022
What adapter do I need for a Sigma AF 75-300 lens on a Canon Rebel XTi SLR?
Question edited for clarity. You get the Sigma lens for the camera in Canon fit. https://www.google.com/search?q=sigma+lens+af+75-300+for+canon+rebel+xti Can you use Sigma lenses on Canon cameras? Since Sigma lenses are made to be fully compatible with Canon cameras, they are backwards-compatible. This means that you can use a Sigma lens on a Canon DSLR camera. Similarly, the Sigma cameras are backwards-compatible with Canon lenses. Macro adapter loses the AF feature. https://www.google.com/search?q=sigma+lens+af+75-300+mount+adapter+ring+for+canon+rebel+xti
3/20/2022 12:10:41 PM • Sigma Cameras • Answered on Mar 20, 2022
Where can I find out how to take apart a Sigma 150-600mm contemporary lens?
Taking it apart is not the problem - re-assembling it will be. Unless you have access to an optical laboratory, where laser instruments can measure the exact tolerances required, don't even think about it. You will be left with a pile of optical components, and a far higher repair bill than if you had just let the experts sort out the problem in the first place.
12/6/2021 7:57:17 PM • Sigma Cameras • Answered on Dec 06, 2021
Sigma 18mm f/3.5 - How to open front end to clean?
Best you don't open it at all as you can damage the lens. Send back to manufacture
1/23/2019 4:32:39 PM • Sigma Cameras • Answered on Jan 23, 2019
Why does my sigma tiffen lens work on my rebel T5i & not on my rebel T2i camera says no connection to lens
Tiffen is a brand of filters not a lens. if your sigma lens will work on 1 camera and not on the other then check the lens mount, electronic contacts, clean them if needed. check the settings in the camera if there needs to be a change.
2/10/2018 4:56:20 AM • Sigma Cameras • Answered on Feb 10, 2018
I have a 170-500 Sigma zoom lens and I need a scheme to understand how to mount it. It was disassembled by an unqualified technician and now he failed to mount it. Thanks.
Take it to a Qualified technician and get it fixed properly. I have this same lens for my Pentax K3, its a very good lens and worth getting it fixed by a proper tech who knows what they are doing.
2/10/2018 3:40:20 AM • Sigma Cameras • Answered on Feb 10, 2018
Sigma DM38 serial 233894
OK - what about it ?
8/2/2017 3:50:23 PM • Sigma Cameras • Answered on Aug 02, 2017
Where to find a english manual for sigma 1609?
This is a cycle computer not a camera. Try Sigma-Sport
5/13/2017 10:36:23 PM • Sigma Cameras • Answered on May 13, 2017
How do you repair sigma 928 amp
Very good question - what is it, and what's wrong with it ?
12/28/2016 11:02:45 PM • Sigma Cameras • Answered on Dec 28, 2016
Hi have a panasonic gx7been given 2 sigma lenses can i fit to my camera 1 x sigma 1:4.5 F=100 - 200mlti coated zoom lens 1 x sigma mini wide 1:2.8 f=28mm multi coated lens thank you
It depends totally on whether your camera takes interchangeable lenses, and if so, do these lenses have the same fitting ? Your camera manual should tell you if you can fit other lenses to the body - if so, follow the steps to remove the lens which is currently attached, and compare the fitments with this lens and the two others you have been given. If you are still not sure, then take it all to your local friendly camera dealer, who will be able to advise you. Do NOT try to force the new lenses onto the body - this is a sure way to render them inoperable.
12/22/2016 4:41:19 PM • Sigma Cameras • Answered on Dec 22, 2016
2answers
How much for sigma af apo 70 210mm lenz nikon thanks yes for my kodak nikonf 401s i hope somebody possible to tell me tank you verry much approx value have a verry good day
Do what anyone else would do. Search for it on Amazon or ebay or any other place you can find the lense....go to the manufacturers page, etc.
12/3/2016 1:29:07 AM • Sigma Cameras • Answered on Dec 03, 2016
On switch on sigma 060 reel does not work
What focal length lens is this ?
11/1/2016 9:35:06 PM • Sigma Cameras • Answered on Nov 01, 2016
My sigma 50-500 lens is lock in 500mm position
I believe on some Sigma lenses there is a switch to lock it in a 'Macro' position, usually at the long end of the zoom range. If this applies to your lens, it may be worth checking that this has not been accidentally set. There may also be some information in the manual whichcame with the lens.
6/26/2016 8:51:24 PM • Sigma Cameras • Answered on Jun 26, 2016
Sigma EF-530 DG ST for Pentax TTL Flash Logo
3 questions posted
Top Sigma Cameras Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sigma Camera Expert? Answer questions, earn points and help others
View Most Popular
Sigma Cameras
  • Sigma Cameras
Most Popular Question
sigma ef 530 dg st not working test or
  • Cameras
