20 Most Recent
Corel WordPerfect Office 12 Standard Edition for PC Questions & Answers
Quattro pro x3 abnormal program termination
1. Click Start, Programs, Accessories and Run.
2. In the open window, type: regedit and click OK.
3. Choose the following path
HKEY_CURRENT_USERS\Software\Corel\User\Assistant\13\Recent Work\Quattro
Pro\
4. Right click on the Quattro Pro folder, select delete.
5. Say yes when prompted to delete the key.
6. Close the Registry Editor
7. Launch Quattro Pro
This key will be re-created when you reopen Quattro Pro. I ran into this problem when when I tried to open a QP SS on my hard drive after previously opening one from my thumb drive. Now I copy to my hard drive first.
4/3/2019 5:27:34 PM •
Corel...
Answered
on Apr 03, 2019
Quattro Pro x3 toolbar has disappeared. How can I restore it?
I had the same problem with Quattro Pro 11 and solved it as follows: right click on the blue header bar, this should bring up a box that has settings in it,left click on settings and then on the left side under Application go to Display and check the boxes until the toolbar that you want appears. It worked for me in version 11 hope it works for you
10/26/2015 4:23:03 PM •
Corel...
Answered
on Oct 26, 2015
Error 1706
Just get another install disk. Borrow one from a friend.
Then all you will need is your serial number.
Reinstall and try that.
Michael
8/3/2015 5:45:39 PM •
Corel...
Answered
on Aug 03, 2015
How do i back up my folders in wordperfect 12
Put a CD in the drive.
Sort the directory by descending Date/time.
Highlight the files you want to backup.
Drag the files to the CD drive.
Your CD drive software should kick in and step you through the next bits.
1/18/2015 1:10:06 PM •
Corel...
Answered
on Jan 18, 2015
Recently installed Corel WordPerfect Office
go to the corel support site and Windows and look for software updates that deal with this issue, most likely there are patches to correct this, use Corel support 1st.
1/18/2015 1:07:49 PM •
Corel...
Answered
on Jan 18, 2015
I have an older version
you have to update the security protocalls as well upgrade to a later vertion
9/11/2011 3:03:30 AM •
Corel...
Answered
on Sep 11, 2011
Because of an XP system
Thank you for using FixYa
I am afraid you wiill have to re-install the program from the origional Cd.
If you do not have one then you will have to contact the manufacturer for your computer. In some cases contacting Word Perfect http://apps.corel.com/lp/wpo/
may be of help.
I hope this was useful and please comment if this was helpful to you.
3/24/2011 3:30:24 PM •
Corel...
Answered
on Mar 24, 2011
I do not want Wordperfect
This can be done with one program that is free follow this link to ccleaner. http://filehippo.com/download_ccleaner/ then you will run cleaner to get rid of history related to wordperfect, then run the registry cleaner and remove all that is selected you will have to run this a few times until nothing comes up. Then go to tools uninstall and remove any thing that has a reference to wordperfect. after you have uninstalled all they above run the cleaner and then run reg cleaner again until all the reg items are cleared. This should take care of your problem.
1/9/2011 11:01:37 PM •
Corel...
Answered
on Jan 09, 2011
Do you have a program that helps you personalize
Photoshop will do it, they have a full working version for 30 days at www.adobe.com
also you can do it online at:
http://www.greatfxbusinesscards.com/
http://www.businesscardland.com/home/
http://www.professorprint.com/
8/1/2010 6:35:55 AM •
Corel...
Answered
on Aug 01, 2010
I have WP 12.
Depending on which one of the built-in pleading styles you selected. Turn on Reveal Codes (Alt + F3), and change the Watermark B to A.
Watermarks are commonly used to customize pleadings with company names and other information. The built-in pleading styles use Watermark B, so if you want to create your own watermark, use Watermark A. You can also edit your waterkarks as per your own requirements.
4/15/2010 4:24:45 AM •
Corel...
Answered
on Apr 15, 2010
