20 Most Recent
Sennheiser RS130 Wireless Headset Questions & Answers
No sound from RS130 headphones
I'm having the same problem with the RS140. Only a few weeks old, and no sound at all coming out (not even the beeps). Have replaced batteries and tried a different audio source. Base station lights are on and indicating it is receiving an audio signal, but nothing is going go the headphones.
I have the Sennheiser HMD 280 PRO Professional
You have to wire the plug to eliminate the voltage sent by the sound card. I can't remember if it's the tip or the sleeve, so you'll have to verify with a volt meter. Use a 3 position plug to solder to the mic wires, just don't connect the wires of the mic to the one that has voltage on it
Sennheiser MM100 bluetooth not working
Yes I had the same problem.
Under some circumstances the MM100 freezes (didn't figure out when just yet).
It's a software issue inside.
Solution: open left speaker (the side with the charge connector and hence the battery).
Discharge the battery (or just short circuit for half a second) and it works again.
Sennheiser should built a reset button on these things.
