20 Most Recent MyNetDeals BlueAction Wireless Bluetooth Headset Hands-free for all Bluetooth Enabled Phones: Apple iPhone, Aud... Wireless Headset Questions & Answers
try 0000 or 9999 there globel codes to reset (it might work)
MyNetDeals... | Answered on Nov 09, 2011
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you've found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!!
MyNetDeals... | Answered on Feb 07, 2010
You have to search the device from your phone and enter the passcode when it is detected.
Make sure you have enter the correct pairing code and your phone has bluetooth 2.0.
MyNetDeals... | Answered on Jan 28, 2010
All you have to do is turn then off and when you're going to turn them back on keep pressing the power button until you hear bluetooth linking, it won't ask for a pin after that.
Radio... | Answered on Oct 11, 2020
there are others with similar issues on fiat 500 radios. seems others are related to having usb devices connected and playing. so maybe its issue with player. or maybe if you have a usb cable connected, try removing it, or even try plugging in a usb stick with some music on it and see if that frees it up. i do know its interconnected with things like phones that can interrupt and PUT ON HOLD the radio so maybe its phone related so there are other inputs at the back i expect which could be grounded if you arent using them maybe...
Radio... | Answered on Oct 10, 2020
Measuring across the commutator opposites is a rough check - if each pair has the same resistance it is probably good but even then there are no guarantees. I have never seen the armature resistance stated for any motor though that doesn't mean such figures don't exist.
It would seem logical that each pair should be isolated but that generally is not how the armature is wired and each commutator segment is the termination of two coils.
In reality there is only three ways to test an armature - either build it into a motor and see if it performs ok, use an automated motor fault analysis machine or one of the dedicated armature testers such as an armature growler.
Radio... | Answered on Aug 01, 2020
Several things come to mind:
* check the batteries in the headsets, are they good?
* check that the transmitter is powered up and connected to the audio circuit in the TV.
Radio... | Answered on Jul 16, 2020
The fashion for nostalgia radio with a modern sound has brought about a clutch of models from only a few manufacturers.
I have only encountered one such that was basically an in-house cabinet with bought in internals, the quality of which was probably reflected in the price and as this was from the lower price bracket the internals were from different sources and badly matched.
I know of no reason to assume other models would be substantially different because although popular they haven't sold in the high numbers that would justify purpose built internals and so the chances are an experienced audio engineer would probably recognise the circuit board as being from a popular hi-fi and be able to provide you with details.
Radio... | Answered on Jun 22, 2020
There are two versions. A free version and a paid version. Make sure you choose the free one and you will not be charged anything. You may need to uninstall the one you have downloaded and reinstall. Do not choose PREMIUM vesion.
Radio... | Answered on Jun 17, 2020
The short answer is no -- the difference between AM and FM is too great though some CB radios were made dual mode, like the President Veep I used to own.
Some CBs that found the way into Britain were powerful sidebanders that offered similar capabilities to unlicensed CB-ers to that official radio hams had to sit exams to enjoy. Some radio hams found it cheaper to have those top-line CBs modified for use on the 11 metre amateur band.
It would be no help to you to obtain a standard FM CB as when the UK was forced to legalise CB radio under the Treaty of Rome, they legalised it at a different frequency as the American frequency was already allocated to radio control, bleepers and other things. Special CB sets were manufactured for the UK market.
Radio... | Answered on Jun 15, 2020
HI.... yes ....it is possible to program them in DMO, this is done in the RSS,.... so I am advised directly from inside Motorola .... but a copy of the RSS is just not available.... ... if fact Motorola seems to officially deny the D700 ever existed ... good luck in finding a solution.
Radio... | Answered on Jun 12, 2020
MyNetDeals BlueAction Wireless Bluetooth Headset Hands-free for all Bluetooth Enabled Phones: Apple iPhone, Aud... Wireless Headset Logo
Popular Tags
11 questions posted
Top MyNetDeals Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a MyNetDeals Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • MyNetDeals Radio Communications
Most Popular Question
lost passkey blue tooth
  • Radio Communications
