20 Most Recent
GE ON-SHLDR BLUTOOTH HDSET Wireless Headset Questions & Answers
Bluedio av890 is not detected............
It is very simple yaa. Instructions are given in the user manual itself.
Switch off the Head set first. Press and hold the On-Off/call/answer key for few long seconds. First the blue light on with blinking. Don't release the switch, hold it further. Then the blue light stops blinking and shows a steady/stable/permanent glow. Now try from your mobile phone with blue tooth set to on. Search for items. On getting the indication of AV890s presence press "connect" switch. Password or Code to connect is "0000" (four times zero).
Now AV890 IS CONNECTED TO YOUR CELL PHONE. O.K.
MUTHUPETCHI V- MADURAI (
[email protected])
How to reset bluedio av890
very simple...hold the call button and the play/pause button while startin the unit up...the led will blink blue thrice and will continuously stay on confirming the reset mode...u can now view the headset as AV890 on ur phone or pc....the code is 0000...confirm it and the connection is authenticated...done...q.e.d
Switch it off.
Press the on off switch for little long duration, till the Light glows steady/permanent (without blinking).
At this stage it can be connected to a device enabled with Blue tooth in "switched on" condition using the passcode "0000" (four times zero)
MUTHUPETCHI V (
[email protected])
Unable to paired with my Nokia 5800
dISCONNECT THE DEVICE FROM SE K800 (Switching off Blue tooth in SE K800). It it is kept on the Blue tooth dwice connects automatically to the mobile phone,
Reset the Blue tooth device pressing for a little long duration till the On/Off indicator light glows permanently.
Then try to connect to the new Phone (Nokia 5800) using the passcode "0000" or the other which will be given in the Users manualy booklet.
MUTHUPETCHI V, MADURAI -
[email protected]
