20 Most Recent
Crown XS1200 Amplifier Questions & Answers
My crown xs1200 won't turn on at all no lights showing at all when Turned on
If you are not seeing any indicators, you may have a fuse open, power transformer, bridge diode, etc, etc.
When you first plug it in, do you hear any clicks coming from the unit itself?
If you need more information, or would like to inquire about having your Crown repaired, please visit my website at audioserviceclinic.com. BTW, I worked for Harman Kardon. Crown is one of their products.
Have a Crown amp xs 1200 that is in fault mode and
You may have two speaker wires touching eachother (shorted) or one of your speakers may have a fault and not giving enough resistance to the amp (shorted). Last option is that one power output transistor is damaged and appears to be a short circuit to the circuit protection system.
I have two Crown XS 1200 and the fault light keeps
A common problem for these is bad capacitors in the power supply, Remove the back from your Amplifier and look at the power supply on the middle section of the amplifier
You will see bid round capacitor that are bulged / domed shaped on top usually these are valued any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same capacitor rating but a higher voltage.
Hope this help in solving the problem....
Power Crown XTi 6000 activates protection and does not generate PWM what could it be?
The Power Crown XTi 6000 is a power amplifier, and it sounds like it is activating its protection circuit and not generating a Pulse Width Modulation (PWM) signal. There could be a few different reasons for this behavior. Some possible causes include:
- Overheating: The amplifier could be overheating, causing the protection circuit to activate in order to prevent damage.
- Short circuit: There could be a short circuit in the amplifier, causing the protection circuit to activate.
- Input signal issue: The input signal to the amplifier could be causing the protection circuit to activate. This could be due to a problem with the source, such as a malfunctioning mixer or a disconnected cable.
- Output impedance or load mismatch: The amplifier may have a mismatch in output impedance or the load impedance which can cause the protection circuit to activate.
- Firmware or software issue : There could be a problem with the firmware or software that controls the amplifier, causing the protection circuit to activate.
Without more information, it's difficult to say for certain what the problem is. It's recommended to check the manual for troubleshooting steps and also check for any possible firmware updates. If problem persist it's recommended to take professional help.
Crown CDi 1000 amp thermal on
Google should have a manual for your 1000 amp thermal and also try on the companies official website too for a manual. Try searching on YouTube as well and YouTube should have videos about amp thermal on - Crown Audio Players & Recorders
Did you receive my DVD of THe Crown Series one?
Hello, Sylvia -
I have no idea what entity you meant to receive your question.
You posted in the Fixya.com website, which is intended for asking and answering questions on how to go about REPAIRING THINGS. Plus, your question landed in the Fixya category for Crown (brand) Audio Players & Recorders.
Perhaps you meant to message Netflix, or your local public library, or a person from whom you borrowed the DVD, or someone to whom you sold the DVD, or . . .
Best wishes.
