20 Most Recent Krups KM7000 10 cup Grind and Brew coffee maker with conical burr Questions & Answers
I have one. there is a setting on how many cup you want 4,6,8,10, or 12 cups
Krups KM7000 10... | Answered on Sep 14, 2015
If it is no longer available why not read the temperature rating on your dead fuse and replace the fuse only?
Krups KM7000 10... | Answered on Aug 18, 2014
The advice is to disconnect it for an hour to reset it.. Lots of issues with that machine
https://www.bean2cup.org/forums/index.php?showtopic=18644
Krups Coffee... | Answered on Aug 20, 2020
It can cause problems if it doesn't work correctly. To test the thermostat in a drip coffee maker: Step 1: Unplug the unit, empty excess water from the reservoir, turn the unit over, and remove the base. ... Step 3: If defective, remove and replace the thermostat with one of the same rating.
https://home.howstuffworks.com/how-to-repair-small-appliances3.htm
Krups Coffee... | Answered on Apr 01, 2020
Error code 5 is a result of one of the following:
Blocked water circuit (water meter, pump, distributor, distributor motor, microswitch)
Krups Coffee... | Answered on Mar 10, 2020
Hi! Did You fixed the problem? I got same error and have no idea whats the point :(
Krups Coffee... | Answered on Feb 17, 2020
That model had a likelihood of the electrovalve growing a green crystal inside the fitting where the teflon tube comes from the boiler. The electrovalve is a solenoid operated tap on the steam wand side accessed by removing the lid and the side cover. I used to take the electrovalve off completely to do the job. To get the teflon tube out you depress the silver collar around the tube towards the fitting and pull on the tube. It won't come out unless you depress the collar. You then unscrew that same fitting and clear the green crystal out with a probe or screwdriver and rinse or blow the fitting out. The fitting was sealed from new into the electrovalve with some sort of sealant product, I used to clean out the threads and use some thread tape, I never had a leak and did heaps of them over the years.
Krups Coffee... | Answered on Nov 07, 2019
Found on the internet:
Try this, remove the tank, the drip tray, the bin on the side and the sliding thing above the bin. Hold down the on and steam buttons while plugging the machine into a live socket, it's either that or the same again but holding down the on button and the program button while plugging it in. You will get a screen that says something like " Remis a something vende" which is French for put it into sale state, you choose "Oui" for yes Hope this helps
Krups Coffee... | Answered on Oct 30, 2019
I found this on the internet:
Google (krups)(171)(manual) without parens OR contact Krups directly to request it.
Krups Coffee... | Answered on Oct 26, 2019
Hello Linda Foster,
If there is NOT an OWNERS MANUAL immediately
available.. there are a huge selection of KRUPPS
machines...
Chose from the attached list...
Find the trouble section... Read & heed
Results for krupps coffee maker var myCallback function document ready...
Hope this helps...
(or REPOST with model number for BETTER QUALITY answers).
Carnac the Magnificent
Krups Coffee... | Answered on Sep 07, 2019
Krups KM7000 10 cup Grind and Brew coffee maker with conical burr Logo
3 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
krups km7000 won 39 t make full pot
  • Coffee Makers & Espresso Machines
