20 Most Recent AudioTrak AT-6100 Amplifier Questions & Answers
How do I connect 3pairs of speakers to an AT-6100? I would like to here the same source, selected on the controller in all 3 locations.
What is the output rating of the amplifier and watts of the speakers. Have to know this to make sure you don't blow your amp.
1/28/2013 3:19:26 AM • AudioTrak... • Answered on Jan 28, 2013
ONN 390 clock radio. How do I turn the alarm OFF on it please?
Question edited for clarity.Question moved to Clock Radios.Disabling the Alarm•? Press the AL1 or AL2 buttons repeatedly until the indicator is no longer lit.ONN Digital Clock Radio User Guide - Manuals+ - manuals.plusManuals+https://manuals.plus > onn > digital-clock-radio-manualJul 16, 2021 - ONN Digital Clock Radio User Guide ; 2 Information and Safety Instructions. 2.1 Important Safety Instructions. 2.2 ; 5 Clock & Sleep Timer. 5.1 ...
3/21/2023 1:09:07 AM • Audio Players &... • Answered 2 days ago
Weconic powered mixer user manual
Question moved from Misc to 'Mixers'. It need the model number in the search query. It looks to be Australian and we are in North America. This should work better for you. https://www.google.com/search?q=Weconic+powered+mixer+user+manual ..
3/19/2023 4:42:56 AM • Audio Players &... • Answered 3 days ago
My Centre speaker for my SP-PWC3 no longer works. Is this a easy repair? It is the amp and not the speaker as the speaker itself works with other lugs. Can I acquire another Mosfet? and replace the de
Unfortunately, it is not likely that you can replace the Mosfet yourself. The Mosfet is part of the amplifier circuit, and it is highly likely that the amplifier board will need to be replaced. Replacing the amplifier board is a complex process that is best left to a qualified technician.
3/17/2023 11:16:12 AM • Audio Players &... • Answered on Mar 17, 2023
How to set alarm Ikea Slabang clock
1. Press and hold the "+" or "-" button to enter the alarm settings. 2. Press the "+" or "-" button to choose the desired hour for the alarm. 3. Press the SET/RESET button to confirm and move to the minutes setting. 4. Press the "+" or "-" button to choose the desired minutes for the alarm. 5. Press the SET/RESET button to confirm and move to the alarm mode setting. 6. Press the "+" or "-" button to choose the desired alarm mode (i.e. one time, daily, or weekdays). 7. Press the SET/RESET button to confirm and activate the alarm. The ALARM indicator light will turn on when the alarm is active. 8. To turn off the alarm, press the SET/RESET button. The ALARM indicator light will turn off when the alarm is deactivated.
3/17/2023 10:54:18 AM • Audio Players &... • Answered on Mar 17, 2023
2answers
AWA 2528 Turntable With CD Player and Recorder. Unable to get functions on it. Power is connected and standby button operates, but then the function button does not respond.
Question edited for clarity and spelling, 'bottom' to 'button'. Question moved from Televisions category. You may be able to clean the workings behind the button with electrical contact cleaner. If that doesn't work, you will need a repair technician. https://www.google.com/search?q=awa+model+2528+function+button+not+working ..
3/15/2023 12:32:41 PM • Audio Players &... • Answered on Mar 15, 2023
How can I turn off shuffle mode in my playlist on alexa?
You can turn off shuffle mode in your playlist on Alexa using the following steps:
  1. Open the Alexa app on your mobile device.
  2. Tap on the "More" tab at the bottom of the screen.
  3. Select "Music & Books" from the list.
  4. Tap on "Amazon Music" or the music service that you are using.
  5. Tap on "Playlists" and select the playlist you want to play.
  6. Tap on the play button to start the playlist.
  7. While the playlist is playing, tap on the bar at the bottom of the screen to expand the player.
  8. Tap on the "Shuffle" button to turn it off.
Alternatively, you can say "Alexa, turn off shuffle" while the playlist is playing to turn off the shuffle mode.
3/15/2023 4:48:29 AM • Audio Players &... • Answered on Mar 15, 2023
Zoom R16 Multitrack SD Recorder Controller and Interface. I am trying to great a new project by pressing the project button but always display (save to No.000) could not go to new project?
Contact the maker Support for strangeness like that.
R16 Multitrack Recorder - ' ZOOM
Zoom Corp https://zoomcorp.com > multi-track-recorders > r16 The Zoom R16 instantly transforms any environment into a recording studio. Not only does it offer 16 tracks for recording, it can also be used as a DAW ...
3/14/2023 2:16:59 AM • Audio Players &... • Answered on Mar 14, 2023
Off button doesn't work on lifestyle 5 music centre
You may need to check the power source, power cord, or power outlet first. If those are working fine, then you may need to contact Bose support or a repair technician to diagnose and fix the issue with the off button.
3/13/2023 4:59:11 PM • Audio Players &... • Answered on Mar 13, 2023
2answers
Watson AS5451 5+1 Audio Speaker System. I need the IR sensor board schematic please?
Question edited for clarity. It doesn't seem to exist apart from a hand written sketch. https://www.google.com/search?q=Watson+as5451+schematic https://www.youtube.com/watch?v=vlJ1bmn3aLM ..
3/12/2023 7:48:49 PM • Audio Players &... • Answered on Mar 12, 2023
Realistic STA-2500 AM/FM Stereo Receiver. I need a schematic for it please?
Question edited for clarity. Help in the link and also specialist forums https://www.google.com/search?q=realistic+sta-2500+stereo+receiver+service+manual ..
3/5/2023 7:26:02 PM • Audio Players &... • Answered on Mar 05, 2023
Model #bc345crs volume knob not right
If the volume knob on your model #bc345crs is not functioning properly, there could be a few potential causes. Here are a few troubleshooting steps you can try:
  1. Check for any debris or blockage around the knob that might be preventing it from turning properly. Clean the area with a soft cloth to remove any dust or dirt.
  2. Try turning the knob in both directions to see if there is any difference in the sound output. If the knob only seems to work in one direction, it could be a sign of a faulty potentiometer, which is the component responsible for regulating the volume.
  3. If cleaning the knob and turning it in both directions doesn't improve the issue, you may need to open up the device and check for any loose connections or damaged components. This should only be attempted by someone with experience working with electronics.
  4. If you are unable to diagnose and fix the issue yourself, it may be best to bring the device to a professional for repair or replacement.
3/3/2023 6:03:30 PM • Audio Players &... • Answered on Mar 03, 2023
Trying to import a CD mp3 songs into tracks on my BR180 It just keeps saying "wrong Disk"
It's possible that the CD is not compatible with the BR180, or there could be an issue with the CD itself. Here are a few things you could try:
  1. Check the format: Make sure the CD is in a format that the BR180 supports, such as MP3 or WAV.
  2. Clean the CD: If the CD is dirty or scratched, it may not play properly. Clean it carefully with a soft cloth or a CD cleaning kit.
  3. Use a different CD: Try using a different CD to see if the issue is with the CD or the player.
  4. Check for firmware updates: Make sure the firmware for the BR180 is up to date. If not, update it to the latest version.
If none of these steps work, it's possible that there may be an issue with the BR180 itself. You may want to contact the manufacturer for further assistance or bring it to a qualified technician for repair.
3/3/2023 11:33:46 AM • Audio Players &... • Answered on Mar 03, 2023
What does maximum power mean in a transformer?
In a transformer, maximum power refers to the highest amount of power that can be transferred from the primary winding to the secondary winding without causing damage to the transformer. The maximum power rating is determined by the physical characteristics and the insulation properties of the transformer. The maximum power rating is usually specified by the manufacturer and can be used to determine the maximum load that the transformer can handle. If the load exceeds the maximum power rating of the transformer, it can overheat, and the insulation may break down, causing damage to the transformer. The maximum power rating is determined by the size of the transformer and the amount of current that can be safely carried by the winding. The number of turns in the winding, the thickness of the wire, and the insulation materials used all affect the maximum power rating. It is important to choose a transformer with a maximum power rating that is suitable for the intended application. Using a transformer with a lower power rating than required can result in poor performance or damage to the transformer while using a transformer with a higher power rating than required may be unnecessary and can increase the cost of the system. In summary, the maximum power rating is an important specification to consider when selecting a transformer for a specific application. It indicates the maximum amount of power that the transformer can handle without being damaged, and selecting a transformer with an appropriate maximum power rating can help ensure safe and reliable operation.
3/2/2023 10:15:24 AM • Audio Players &... • Answered on Mar 02, 2023
AudioTrak AT-6100 Amplifier Logo
Popular Tags
1 questions posted
Top AudioTrak Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an AudioTrak Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • AudioTrak Audio Players & Recorders
Most Popular Question
connect 3pairs speakers 6100 like here
  • Audio Players & Recorders
