20 Most Recent
Sabrent USB-AVCPT Video Capture Questions & Answers
I am unable to capture
you need a programto conver raw vhs into H.284 digital I would recommend FinalCut pro.
Now if its not detecing your VHS on the inputs then the device is not fucntioning like it should. I would try it on another computer to see if that aint the issue. It could also be the device not detecting correctly otherwise malfuction. Also most tapes/Movies have copyright protection and saying that if you doing a movie that could be the issue to Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
9/9/2014 7:49:10 PM •
Sabrent...
Answered
on Sep 09, 2014
I installed all programs on
The only thing I could recommend is to make sure you have the proper drivers installed. You can google:
"*insert product name** driver"
And it should be one of the first links.
7/6/2011 8:38:30 PM •
Sabrent...
Answered
on Jul 06, 2011
Tis device can not start
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
3/26/2011 3:26:35 PM •
Sabrent...
Answered
on Mar 26, 2011
Installed drivers from DVD on
What you do is you right click your screen and go down to scrren resolution. Then make sure that your display is extended to your television.
3/24/2011 2:10:21 AM •
Sabrent...
Answered
on Mar 24, 2011
Video capture with this device is great, but I
Here are couple websites with drivers:
one ,
two. Choose device familiar with yours download and install latest drivers - your device must be unplugged. After installation you'll be prompted to restart Windows, after restart plug your device and check if it is installed in
Device Manager properly. If any of devices has yellow exclamation mark, try to manually update the driver and choose - Let me choose the driver to install the correct driver should appear in the menu. After drivers are installed you have to properly connect wires and configure format PAL or NTSC, resolution and so on. Good luck!
And by the way there is no good driver for Windows 7 x64 it can be installed but
Blue screens from time to time.
2/2/2011 10:53:31 PM •
Sabrent...
Answered
on Feb 02, 2011
What are the red yellow
The side with 3 RCA jacks, red, white, and yellow, is for connecting the USB to a composite video cable. The black connects to an S-video cable; you would still use the red and white plugs to carry the audio. At least the older XBox's had composite video outputs; you just need the composite video cable (which you may have as they came with many video devices (VCRs, DVD players, video cameras).)
If you need to connect this Video capture device to another type of output, you will need a converter. Component to composite video would be one option. However, you will have signal loss with any converter.
I hope this helps.
(Composite video cables: yellow carries video, red and white connectors carry the Right and Left audio)
11/22/2010 1:33:15 AM •
Sabrent...
Answered
on Nov 22, 2010
Serial number?
Sometimes the serial is placed on a yellow sticker on the shrink wrap. You can also call the manufacturer, give them the serial number and they can provide you with the serial number.
5/28/2010 12:49:05 AM •
Sabrent...
Answered
on May 28, 2010
