20 Most Recent Lenovo IdeaPad Y710 (59012816) PC Notebook Questions & Answers
there is a problem of you operating system
Lenovo IdeaPad... | Answered on Oct 30, 2010
The issue of Error Code 0xc0000225 generally occurs when Windows cannot find the system files used for booting, boot configuration data files are being missed or corrupted while accessing any application or system files/programs.
Check The Printer's Connection
Restart Your Device
Make Sure Your Printer is Online
FULL steps in this blog- Error Code 0xc0000225
View the Original blog
Website:-
www.hptechnicalsupportphonenumber.com/blog/fix-hp-stream-notebook-error-code-0xc0000225/
Lenovo IdeaPad... | Answered on Apr 07, 2020
If you bought the Lenovo at a local dealer, take it back to them. If you bought it through an online dealer, I recommend you track down Lenovo customer support.
Lenovo IdeaPad... | Answered on Sep 05, 2019
really why not ask the game maker directly for help with your w10.
here they are right>?
https://www.mygames.com/
so what do THEY say , it is there code, running.
does Tetris fail or just your games, unnamed,
this maker is bad company they take over your PC
why run this crappp? it takes over your browser,
and more, and is bad.
the do not even have minimum system requirement there.
nor support. avoid like the Plague.
Lenovo IdeaPad... | Answered on Jun 30, 2019
Restart your computer & start tapping f/8 immediately and keep tapping until black screen comes up. Use the arrow keys to select safe mode the press enter. It will start up in safe mode in each corner, the icons are all out of shape and a help window will open. Close that window. Then go to: Start, Accessories, System Tools, right click System Restore & send to desk top.(The reason to do that will be to use it easier ANYTIME you have a problem.) Then do a system restore back to a time before you had the problem. That should resolve it. If not you will have to do a Recovery after saving everything you want to keep on a Flash Drive. On start, type recovery & go there & follow directions.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Lenovo IdeaPad... | Answered on Apr 16, 2019
It's a mechanical problem with the wiring and contacts along the edge of the screen. No "fix" except screen replacement.
Lenovo IdeaPad... | Answered on Apr 01, 2019
Sarthak Sharma and Carla Bunis want more answers
there are many ways to EJECT
1: the botton on the try , is marked EJECT
do so>>
2: the tiny hole on front of same tray use unbent paper clip, stuffed in hole and try ejects manually.even drive chassis in hand. by self.
3: windows is this ,not stated,but windows explorer
right click the DRIVE D:>? and click REJECT.
4: in windows, make sure the device manager does not list, the DVD as dead,red/yellow or unknown.
if device manager shows the drive missing or bad you need to get the new driver for it.
so right click the drive (be online) and click update drive.
no full model number stated, 330 is not full. number. so says Lenovo.
btw even a empty tray will eject.
if the disk is cracked or label fell , then only way
2 might work and cleaning the jam by HAND.
if way 2 fails.
only total dismantling the DVD drive can fix it.
true jams are hard work. ok?> physical world deal there.
not one poster here said, the button is dead.
saving this post from going to ALL wAYS it can fail and long.
Lenovo IdeaPad... | Answered on Feb 03, 2019
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Lenovo IdeaPad... | Answered on Jan 23, 2019
Lenovo ideapad 330S
330S-nnnnnn what is the sub number on model.
nnnnnn is 11 to 17 and up to 3 latters at the end.
4 years old max 2015 made.
answering for dead screen, no text, no lenovo logo icon on screen.
no prompts, and BIOS hot keys are dead. ok?
remove AC pack and all usb devices
push power button for 10 to 30 seconds and release
this is Forced cold power restart,
NOW is this a cure to the problem?> with power pack put back in? plugged end to end, AC wall to PC.
OK no is not:
remove AC power pack. unplug it)
next is the more hard, remove PC covers 10 screws. page 34
and unplug the battery connector.
as seen on page 36 of your service manual below.
then plug in the AC Power pack now.
does the PC run ok with no 4 year old battery inside?
end no battery test,what was the results now?
moving the battery inside any PC does not make it last longer, only harder to remove and service.
the price we pay for Light and thin.
"higher cost of ownership"
see page 36
https://download.lenovo.com/consumer/mobiles_pub/ideapad_300s-11ibr_hmm_201509.pdf
you asked I told.
Lenovo IdeaPad... | Answered on Jan 19, 2019
Try getting the latest version of iTunes, or reinstall your current version.
Lenovo IdeaPad... | Answered on Nov 13, 2017
You will need a separate recovery disk. Sounds like the recovery partition of your HDD got overwritten. Maybe you can create a windows WinPE (microsoft docs) and use that. This says what to do once you have a recovery disk.
https://pureinfotech.com/how-to-uninstall-windows-8-developer-preview-and-restore-windows-7-step-by-step/
Lenovo IdeaPad... | Answered on Sep 25, 2017
First of all, you need the present password. Then straight after turning the computer on you press F12 or insert multiple times after each other. That way you will stop the normal boot and enter the BIOS settings. There you most likely will be prompted for the password and then under security you can disable or change it.
Lenovo IdeaPad... | Answered on Jun 26, 2017
Each computer on your network should have network discovery turned on. They should also be a part of the same group or network. The default in Windows is WORK, but you can change the name to whatever you would prefer.
How to Turn on Network Discovery in Windows 7
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
Lenovo IdeaPad... | Answered on Jul 18, 2016
Return it straight away. A new machine should not do this. It will be a hardware issue, or a driver issue.
Lenovo IdeaPad... | Answered on May 15, 2016
you create those yourself , but when you do write them down in a notebook in case you forget what you used .
Lenovo IdeaPad... | Answered on Mar 31, 2016
Lenovo IdeaPad Y710 (59012816) PC Notebook Logo
1 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
machine just reboots after clicking
  • Computers & Internet
