20 Most Recent
UltraLast ULAC3660L For Acer Aspire 3660/3680/5600 Series Questions & Answers
Built in webcam cannot detected by its software
Make sure the program that your using doesn't have the camera offline.
Then if the driver installed properly and you see the camera listed in the device manager then the next step would be to open up the LCD. You'll need to turn off the laptop.
Take the rubbers off of the lcd bezel then unscrew the screws out of there. Take off the lcd front bezel and this will expose the screen and also expose the built in webcam. Make sure the connector for the webcam is actually plugged in. You might have to reseat the connector or best thing is disconnect it and then reconnect it back.
Now go ahead and turn it on and use the webcam program and see if it works, if it still doesn't work then the built in webcam is bad.
1/23/2013 2:31:43 PM •
UltraLast...
Answered
on Jan 23, 2013
My laptop shuts down automatically.is there any
Possible but not likely. Sounds more like possibly overheating (sitting on unbreathable surface, fan(s) broken)...compromised power supply...battery bad (if running on battery). Check to see if fans are running. If fans are on the bottom of the unit make sure air can get to them. Try running on AC with battery out see if problem persists.
Hard to be sure without having possession of computer.
Hope this helps.
Good luck
10/18/2010 12:50:49 PM •
UltraLast...
Answered
on Oct 18, 2010
Mouse pad does not move pointer on my acer 5515
Have you done anything that caused this to happen - reinstall Windows for example?
You probably need to re-install the touchpad drivers. Go to Acer support site and download and install touchpad drivers for your model.
8/29/2009 7:30:47 AM •
UltraLast...
Answered
on Aug 29, 2009
No tiene sonido la acabo de configurar
dear marcialpol15,
Connect your computer to the internet, open your browser and minimize it, the on start menu, find 'My Computer' and right click on it and choose the 'properties' on context menu, on the properties box, click the hardware tabs, and choose the device manager, wait... and on yhe device manager click the yellow question mark appear on the sound device, right click and choose the 'Update driver'... Let the wizard take you to the web and find it, if driver available on the web, download it and save on your folder somewhere in you computer. After dowload complete, do the last step and direct your soundCard driver to the folder you have already download.
GoodLuck!
8/25/2009 11:58:29 AM •
UltraLast...
Answered
on Aug 25, 2009
My laptop can't connect to the internet
go to website www.acer.nl
http://www.acer.nl/acer/service.do?LanguageISOCtxParam=nl&miu10einu24.current.attN2B2F2EEF=3744&sp=page15e&ctx2.c2att1=3&miu10ekcond13.attN2B2F2EEF=3744&CountryISOCtxParam=NL&ctx1.att21k=1&CRC=2939325947
8/22/2009 8:08:38 PM •
UltraLast...
Answered
on Aug 22, 2009
Acer dark screen problem
your problem is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google.
They are cheap to replace google your model with inverter at the end..
I cannot say how many I have replaced in Acer systems
I know for a FACT this is the problem. They are cheap inverters.
When you replace this one i would expect it to last longer :)
8/20/2009 5:14:28 AM •
UltraLast...
Answered
on Aug 20, 2009
Codes
Hi I encounter this problem before. one of those 2.5 hdd. The only way to resolve this is to install the recovery cd and thru format the HDD. I know you will lose all your file. So far that is the solution I can provide you. Until now I am looking for a way to resolve this problem with out losing any file and still restore the hard drive. I hope this will help you to restart your laptop and without spending or buying a new hard drive.
8/15/2009 2:23:44 PM •
UltraLast...
Answered
on Aug 15, 2009
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
