20 Most Recent EliteGroup MB ECS A770M-A 770 SB600 AM2+ RTL Motherboard Questions & Answers
My secondary hard disk shuts off randomly and the computer freezes.
Hi Marko Stanarevic: I make this video for help ...wish you solve your problem
1/20/2013 3:04:30 PM • EliteGroup MB... • Answered on Jan 20, 2013
I just ordered two
perhaps you forgot to plug the case switch connectors
you know, power, reset, HDD light...
7/18/2011 5:27:46 PM • EliteGroup MB... • Answered on Jul 18, 2011
Sound Only through Headphones -ECS A770M-A
Start button>settings>control panel>sounds and audio devices>
Middle tab [audio]
default device, hit the down arrow
and choose the other device
I keep a shortcut on quicklaunch because I switch them all the time.
7/5/2011 11:18:23 PM • EliteGroup MB... • Answered on Jul 05, 2011
Cmos settings incorrect press F1 for setup.
bios setup F1
make sure you load optimal/default settings and your hard drive primary/Operating system drive boots first F10 save ok enter
7/4/2010 2:36:35 AM • EliteGroup MB... • Answered on Jul 04, 2010
2answers
The ECS A770M-A onboard REALtek audio problem
if everything is up to date, softwares, and other related issues you had mentioned...seems like the audio amplifier in your pc is not functioning or it had been damamged...alc880 high definition audio driver, try to uininstall it, and if you had tried any other related alc drivers to install..remove it from the system and re-install it..if it works..no problem, if it dosnt..try to play your media player, if you are able to see graphics moving...then your audio amp is damaged..check out
10/14/2009 8:44:21 AM • EliteGroup MB... • Answered on Oct 14, 2009
After replacing the A770-a battery due to low
Sounds like a problem with the power pack. Try with another power pack to confirm.
9/19/2009 9:55:20 PM • EliteGroup MB... • Answered on Sep 19, 2009
No Power
Check rating of power supply and make sure this is meeting the specifications of the motherboard. Check memory compatibility. This can play some serious tricks. Unplug motherboard and try powering up power supply by itself. Possibly you are short of power, a faulty supply or faulty motherboard. Wiring is normally pretty straightforward and connectors have guiding features to avoid erroneous assembly.
8/28/2009 1:05:44 PM • EliteGroup MB... • Answered on Aug 28, 2009
A770m-aboot problem
Check the power supply, if its working right you should hear a beep on this motherboard.
8/6/2009 8:24:18 PM • EliteGroup MB... • Answered on Aug 06, 2009
Hello, I have ecs a770m-a motherboard.My
Remove the CMOS battery off the motherboard and do a reset on the BIOS. At the switch it shorts and turns the power supply on. See link:
http://www.techpowerup.com/articles/other/22
those two header connections should lead to the Power Supply Connector.
8/6/2009 7:58:08 PM • EliteGroup MB... • Answered on Aug 06, 2009
2answers
Hi i have a ecs a770m-a m/board inno 8800gts 2gig
You need to replace the small battery on your motherboard, You can get them at Radio Shack. The battery number is CR2032 it looks about like a quarter. With your computer off, open your computer case find the battery in its holder pop it out and replace it with the new one. Now when you power the system back on go into setup usually by pressing either the "del" key or "F2" key after you go to setup exit the screen by pressing either "esc" or "F10" your system will finish booting and you should be back up and running.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
6/19/2009 7:17:14 PM • EliteGroup MB... • Answered on Jun 19, 2009
2answers
Hi all was ok in till i removed my hard drie
hi im josh in cebu phils.may i help you? friend try to do this things. first i suggest to change new ide or sata cable.if still persist.try the following:
Boot order: Traditionally, a computer is set to boot first from the floppy drive, and then from the main hard drive (Drive C). This means that the computer will check the floppy drive first for boot files. If there is no disk in the floppy drive, the computer will then go to the hard drive to look for boot files. That is why if you leave a non-bootable floppy disk in the drive and try to boot up, you'll get an error message such as "NTLDR is missing. Press any key to restart." or "Non-system disk or disk error." This can be changed to pretty much any order, including CD and DVD drives. It is useful when installing Windows on a new or just-formatted computer to set the computer to boot first from a CD-ROM drive, and then insert the Windows installation CD-ROM into that drive. This saves you from having to use boot floppies that might or might not come with the Windows CD-ROM. Good luck.
3/12/2009 2:24:26 AM • EliteGroup MB... • Answered on Mar 12, 2009
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
EliteGroup MB ECS A770M-A 770 SB600 AM2+ RTL Motherboard Logo
16 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
cmos settings incorrect press f1 setup
  • Computers & Internet
