sounds like the amps not rated for the resistance tha subs have it running at....are they a dual 2 or dual 4 ohm?is the amp rated for 1ohm? sounds like amps going into protect mode
Sounds like you either shorted something out or overloaded the amp. Is there any odor coming from it? If so It will need to be repaired or replaced. What did you have connected to it and how was it wired?
In your world, what does best results mean to you.
how are the hifonics mounted? open air, closed box, vented box (optimized to what freq)? trunk or inside vehicle?
all these variations weigh heavily on your configuration. As does what 'best results" means to you.
