20 Most Recent
Belkin TuneBase FM (F8Z049-BLK) Car Adapter, FM Transmitter, Car Mount for Apple iPod (2543448) Questions & Answers
I can not get it
Plug the device into your power plug in the car. This kind of adapter uses radio frequencies to tune it in so make sure that your radio on your car is set to the same as the device. This will only work if there is no station for that specific frequency - for example, of the device is set to 88.8 FM and there is a local station set to that frequency, all you will hear is static. There is an option on the device to change was frequncy is it set to, tune your radio to the matching number and it should work.
If your problem is getting it connected, there will either be a wire at the bottom to plug into your ipod (goes in the same place as it does when you plug it into the computer) or it will be mounted right on the device. Make sure it is fully attached on both sides or it won't work.
Where can i get the
Try a local Radio Shack,ask a sales person to help.You need to know the size,milliamp ect.This is a small sale item for them so don't go at a busy time.
Honda accord compatibility
The unit should be compatible with any vehicle that has a working cigarette lighter port or 12volt power point.
Fuse
Its actually a 7A 250V fuse. Unfortunately, I have not had any luck finding it. Also, 7A 250V fuse come in two sizes, a large and a small. So you will need the small
Will my Belkin ITE Power supply Model No.AC08
Yes as long as the wattage voltage etc... align between the device and the max output of the adapter you should be just fine in this particular case. I have the same adapter and I can not even remember what it initially came with but it has been so handy that I will keep it as long as it lasts. ;)
I have a Belkin iPod
You would have to read the warranty on the product to know for sure if it is in fact, still under warranty. They could possibly tell you that because "you" broke it that it isnt a problem with the device itself. If it came apart that easily i'd call and complain. It may not be working because if the insides fell out some wires may not be attached anymore, or a vital peice of the chip inside of it got damaged somehow so i hope you don't talk to a rude person in tech support for it becuase i think that may be your only option.
