20 Most Recent
SanDisk Sansa SDAMX-FCT (619659024598) FM Transmitter Questions & Answers
Como gravo fotos en este sandisk?
Perdóneme, no hablo español muy bien sino que intentaré contestar a su pregunta. Usted debe instalar el software que vino con su Sansa si usted quiere utilizar la función del photo.
Fm 6709
Try this: disconnect the player from the computer, turn it off,
hold in the volume + button, and reconnect the player to the computer
while holding the volume + button in. Keep holding the volume + button
for an additional 5-50 seconds. Windows should eventually go into
recovery mode and revive the player- it will pop up a window that says
Found New Hardware Wizard.
Sandisk Sansa E250 screwup
you might be able to get back the operating software by using a software repository (ie softonic or softpedia) or the Sandisk website to upload the installation material onto your music player. Then after the player is functioning properly again, you can download your past music to the player from your computer.
Thank you.
Not suport vidio & photo in my sansa i pot
Hi, use this link it will be of great help to you...
kb.sandisk.com/app/answers/detail/a_id/42
Also to solve the Video and photo format, you will need to check on the manual what format does it play with.
If the format is different from the video format you want to download inside the player, you will be needing a converter to convert the video format to the player format of video..
you can download a video converter from the link below.."
effectmatrix.com/total-video-converter/
Have a nice day...
