20 Most Recent Pelican Brass Peli-Lock n/a Item: 2608 Questions & Answers
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell [email protected]
Good luck
Locks &... | Answered on Jan 13, 2020
hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or [email protected]
Locks &... | Answered on Dec 16, 2019
I read this elsewhere. it's worth a try...
"I had the same problem, batteries dead and i could not find the keys. I read on the internet that if you get a hairdryer, and heat up the front of the safe where the keypad is and where the spare key goes in this will work, i thought anything is worth a try. So i held the hairdryer there for a bout 15 mins and what happens is the heat slowly boosts the battery life, enabling you to open the safe. You will notice that you start to get a beep noise from the key pad. even though i was getting a beep from the pad it didnt open straight away but after about 10 mins i retried the code and it worked. Make sure you replace the batteries immediately before closing the safe again "
there should be an access code maybe on the back of the device, if you have mounted it, remove it and inspect the back of it for code also check for code anywhere inside the the advertisement from package. if you bought it from a neighbor and it was opened, give it back,,,nice try
Locks &... | Answered on Dec 05, 2019
Google (micromark)(MM40042)(manual) without prens OR contact Micromark diectly to request.
Locks &... | Answered on Nov 27, 2019
Thats a job for a locksmith locally.
CLICK HERE FOR MORE INFO
Locks &... | Answered on Nov 25, 2019
Gunsafes are meant to be difficult to open. I'm unsure as to your logic in the novel use of that 9v battery, all it would have done was to short circuit the battery.
Remington's own website gives you only one option if you're a US resident, "Contact Liberty Safes, the licensee, at 800-247-5625 for assistance with obtaining the combination to your safe.
If your safe is a low cost model and you need access quickly then you'll have to cut the safe open, but more expensive models are resistant to this form of attack and the safe will need to be scrapped and replaced afterwards.
Set the thumbturn to “unlocked” (vertical) position before u remove the inside cover to change the battery. Keep it in “unlocked” until you have completed the battery change and put the inside cover back on. Now u can put thumbturn in “locked” position and test your code. This is how I solved the same problem for me. Hope it works for you.
Locks &... | Answered on Nov 06, 2019
Pelican Brass Peli-Lock n/a Item: 2608 Logo
0 questions posted
Top Pelican Locks & Locksmithing Experts
john h
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Pelican Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Pelican Locks & Locksmithing
Most Popular Question
vingcard lockset interior handle stuck
  • Locks & Locksmithing
